Something Loose???
Old Oct 16, 2010 | 08:37 AM
bryansdc's Avatar
bryansdc is infamous around these parts
Something Loose???
My new Turbo has a small rattle that is mostly prevalent on the freeway.It is right by the rear back passenger window or seatbelt area.It almost seems as something might be loose which is causing the rattle.Non-existent at low speeds.Any ideas where to look or what I can do.Nothing really to tighten back there so I am kind a lost.Thanks...
Old Oct 16, 2010 | 08:44 AM
bbywu's Avatar
Old Oct 16, 2010 | 09:56 AM
jhbrennan's Avatar
Check to make sure the fold down portion of the rear seat is fully latched.
Old Oct 16, 2010 | 10:13 AM
bryansdc's Avatar
I have it folded down figuring it might have been the latch on the seat but that is not the problem..but thanks
Old Oct 16, 2010 | 10:42 AM
PT Doc's Avatar
PT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond reputePT Doc has a reputation beyond repute
Don't rack your head-take it to a dealer. Chances are you are not the only one with this and they will have seen this before. Could be a loose piece of metal, nut not really tight enough. They'll sort it out and make sure that it won't happen again, hopefully.
Old Oct 19, 2010 | 11:48 AM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
Have you had your bumper removed recently? If so, there is a screw that goes on the upper portion of the bumper (inside the inner fender liner) that might be loose. The clip that holds the screw might be a bit deformed and needs to be straigthened out.
Old Oct 19, 2010 | 11:50 AM
bryansdc's Avatar
Its a brand new car...
Old Oct 19, 2010 | 02:07 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
possibly the ashtray
Old Oct 19, 2010 | 02:42 PM
bryansdc's Avatar
It's in the back rear passenger side of the car...but thanks
Old Nov 7, 2010 | 03:21 AM
crism's Avatar
crism is infamous around these parts
Hi all, this is my first post, but thought I could jump in now and help. Have been a long time reader here by the way. I have had the same problem and it appeared to be a wiring harness that caused this rattle. Have the cover of the seat belt and cover right above the rear window removed and check for loose clamps. If everythink is OK, try to fit it with some kind of foam to make it tight. Hope that helps. Christian
xbox_fan
Oct 25, 2015 09:03 PM
Collinsjd
Sep 29, 2015 09:38 AM
flat_6
New Member Introductions
Sep 27, 2015 11:47 PM
richard181
Bentley
Sep 21, 2015 10:35 AM
