Intercoolers...997,2 Vs 997,1...Game over...
Old Nov 18, 2010 | 10:31 AM
  #46
cannga's Avatar
Originally Posted by skandalis447
Tomorrow i will install new tires,and so will be able to run the car at higher speeds...if feels faster,especialy at high speeds...By observing OEM ICs logs at speeds over 220-230 and up to 270km,i saw that the car was running very rich there...which is a sign of a)less dense air or b)DME adds fuel to prevent detonation from high IAT...
In order to have identical 60-130 run as my 6,48 i need to have the same ambient temp...i hope for the weather to cool down...
Yes unless I am mistaken, what you are showing is 2 cars, run at 2 different times. Since the difference is not just big, but MONUMENTAL, the test begs for more stringent criteria.
I think it would be a lot more convincing to have the test done in the same car, before and after intercooler change, with the 2 parameters followed:
1. Data logging of IAT
2. 60-130 times, or whatever time deems necessary
1 would show that yes the intercooler did lower the temp that significantly.
2 would show that the better thermal efficiency did not come at a cost, such as pressure efficiency.
Once again, great thread, great work.
Old Nov 18, 2010 | 10:54 AM
  #47
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
No...you misunderstood me...All the tests were made to my car...So there is only one car...Kostas was codriver holding the laptop...One is with 997,1TT ICs and the other is with 997,2TTICs...Also as i stated before the run logger is the forth in a row with the 997,2TT ICs...all of them had same iat...very solid and constant values...I can show you 2nd and 3rd run with 997,1TT OEM ics to see that max IAT was 65 in first run and 70 at second...
Old Nov 18, 2010 | 11:38 AM
  #48
cannga's Avatar
Wow -- then very impressive indeed. Thanks for the correction. I am still shaking my head in disbelief. I could understand a few degrees -- but 18-20 centigrade difference? That's MONUMENTAL.
Are we missing something here or is it for real? If it is --- AMAZING! Any pro would like to chime in please? Particularly vendors who are making and selling intercoolers? How could there be such a huge difference, just one generation apart?
It will be very interesting to see how VBox times compare. Thanks again for taking the time to test and post.
Old Nov 18, 2010 | 11:46 AM
  #49
pete95zhn's Avatar
pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !pete95zhn Is a GOD !
That's something you're not going to see...emperor's clothes etc.
R&D, even car factories do that. The most amazing part with these IC's is that they cost just about $900 / pair.
Old Nov 18, 2010 | 12:37 PM
  #50
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
But... what if you do 5 consecutive 60-130 runs and look at the results of the later runs?
The car with the better intercooler will show its superiority in the latter runs, no?
That's what did I mean saying "consistent", sorry for the poor US language
Old Nov 18, 2010 | 12:38 PM
  #51
K24F's Avatar
Old Nov 18, 2010 | 02:05 PM
  #52
K24F's Avatar
Ok, mine 997.2 Ic's are ordered, perhap's not the "Best" but sure better than stock...
My VTG's are bigger than stock, producing a bit less IAT than small, so those parts might work correctly with...
If possible with my tuner we will data before and after the mounting with the same ECU, and after a map optimisation.
Old Nov 21, 2010 | 12:59 AM
  #53
cannga's Avatar
Also i ve logged two more sets of aftermarket ICs...But I wont post results...I respect that both companies acted proffesional and refunded them...
My car has APR tune,which presses stock VTGs to their limits...The most difficult job of an IC is to be able to cool properly a small turbo that is pressed hard and tends to heat more...Larger turbos have better efficiency and so they dont heat up as much the air...
On the other hand a small decrease in air flow wont hurt...we have to see it as a total,a little less flow BUT much less air temp=more dense air...so less volume of air is needed to bring the same o2...
Skandalis, you don't have to tell me which brand, but did I understand correctly that you've compared IAT's of 4 different intercoolers: stock 997.1, stock 997.2, and two after-market units, and the 2 after-market units actually did worse than the 2 stock units?
1. Was the methodology of comparison similar between the 4 intercoolers?
2. Were the results "repeatable"? (Done multiple times and same result every time?)
3. Why not posting the results of the 2 after-market units? As long as you don't name names and have good intention, I don't see why not? It's fun, educational, and allow others to evaluate your test results critically (to be fair to the after-market vendors).
Thanks.
Old Nov 21, 2010 | 06:34 AM
  #54
Gerardo's Avatar
Gerardo is infamous around these partsGerardo is infamous around these parts
IC ducts needed minor trimming...GT2RS ICs are thicker...Everything else is bolt on...
Is GT2 RS's IC same as 997,2 ?
Thanks!
Old Nov 21, 2010 | 10:12 AM
  #55
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
^ Yes
Old Nov 21, 2010 | 11:13 PM
  #56
speed21's Avatar
Speed 21,when I pay almost $4000 for a set of ICs and they have 8 to 12 degC HIGHER than OEM ICs,i simply return them back...and ask for refund...
Ok. That makes sense. But whats the story with your tires? Have you tried tire rack. They can surely get you the right tires fast and probably way cheeper than where you are. Hows the benefits of the new ics shown up in the 130 to 200 time? Did the others make the car slower?
Old Nov 22, 2010 | 04:33 PM
  #57
cannga's Avatar
Yes! Repeatability/reproducibility :-) is important. For example, how about studying the IAT not with a 60-130 run, but just cruising around at 70. Is there a difference there? Next example, could there be something in Skandalis's particular car/methodology/measurement/etc. that causes such a significant difference?
There must be several people on this forum who have used those other after-market intercoolers. Has no one done a comparison of IAT before and after change?!
The 20 centigrade difference between one generation to the next of intercooler keeps forcing me to ask: What are we missing in this study? I have my doubt, but the strange silence by after-cooler vendor is making me think, maybe Skandalis and earl have really discovered something BIG after all :-).
Old Nov 22, 2010 | 04:40 PM
  #58
bbywu's Avatar
If you're just cruising at any speed, there is not load on the engine, no boost to increase temps. To test an IC, you have to subject it to engine load, no?
  #59
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
Yes! Repeatability/reproducibility :-) is important. For example, how about studying the IAT not with a 60-130 run, but just cruising around at 70. Is there a difference there? Next example, could there be something in Skandalis's particular car that causes such a significant difference?
There must be several people on this forum who have used those other after-market intercoolers. Have no one done a comparison of IAT before and after change?!
The 20 centigrade difference between one generation to the next of intercooler keeps forcing me to ask: What are we missing in this study?I have my doubt, but the strange silence by after-cooler vendor is making me think, maybe Skandalis and earl has really discovered something BIG.
i was talking with earl as hes done more research into this then i have but it seems were seeing the difference in Intercoolers that are track oreientated for extended use versus intercoolers that flow wonderfully for big hp numbers and are great until they are heat soaked.
Old Nov 22, 2010 | 04:42 PM
  #60
id be interested in some data taken from a car on the track for a long period to make sure the coolers were heat soaked and see how they react
