Wheel Offset Questions
Old Feb 3, 2011 | 01:37 PM
jhbrennan's Avatar
Originally Posted by Serpentene
Spacers...disasters in waiting......
If you must..
Please purchase a wider wheel!!!!
Why a "disaster in waiting" if Porsche ships 2 high performance cars (GT2 and GT3RS) with 5mm spacers as OEM.
Old Feb 3, 2011 | 08:19 PM
speed21's Avatar
Originally Posted by ruf_turbo
Earlier I misspoke on the spacer size I use. When I said 5mm, I meant 7mm.
So it's 7mm/15mm on stock .1 wheels, and 7mm/7mm on the 12" GT2 wheels.
But Barry what are you ride heights and alignment settings?? I recall your car as having fully adjustable coilovers? Remembering any additional camber will move the top of the wheel in.....unless of course you are acheiving the extra neg by moving in the upper front strut or adjustable upper rear arm (if fitted). Point here is these settings alone will affect the spacer widths you can get away with vs a stock alignment and ride height.
I know Karim says it is an inexpensive enough excercise to trial the possibilities but my money is on a 5F max and 7R max max combo. It'll be interesting to see. I still maintain there must be a difference in the control arm lengths or something else that sets the .2tt wheels out further in the guards than .1tt
C'mon Karim dont keep us waiting!! Bets are happening in the interim .
Old Feb 7, 2011 | 10:32 PM
k_ddsl's Avatar
k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !k_ddsl Is a GOD !
Well, hate to disappoint but I decided to forgo the spacers...
But all for a good cause...
Originally Posted by bumperpip
5) Do your homework. Get a VERY GOOD wheel manufacturer (there are several)
to build your wheels with PROPER OFFSETS.
[EDIT]
Go forth and speak no more of spacers.
I need a drink.
bumperpip got me thinking and I re-evaluated this whole wheels thing.
Since there is not much I can do anymore for upgrading my car power wise until our friends at CMS release the PDK upgrade, etc...
I decided that the best way for me to improve the looks of the car AND get some added performance is this:
And since the offset on these wheels do not require any spacers and they are about 14KG lighter than my stock wheels ====> win/win/lose performance/looks/self-impoverishment situation.
BBS FI wheels in satin charcoal/diamond cut finish with TPMS valves and ability to accept both BBS and Porsche center caps.
Ordered, coming soon to a 997.2 Turbo near you!
Old Feb 7, 2011 | 11:13 PM
speed21's Avatar
And since the offset on these wheel do not require any spacers and they are about 14KG lighter than my stock wheels ====> win/win/lose performance/looks/self-impoverishment situation.
Well done Karim!!!! Spacers can be a PITA anyway. No doubt about you tho.....you sure do go in hard. These arent cheap i hear so I can see that pot emptying real fast at this rate.
No substitute for lightweight monoblocks....you should feel the difference . How long do we now have to wait before we get to see pics?
Old Feb 7, 2011 | 11:49 PM
ruf_turbo's Avatar
ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !ruf_turbo Is a GOD !
Sorry Paul, I missed seeing your message earlier.
The car has been lowered ~1" and the alignment is not REAL aggressive but more than stock. As you say, additional negative camber will move the top of the wheel in, but adding a spacer moves the entire wheel farther out so there is still plenty of clearance on the inside of the wheel.
FWIW the .1tt with a stock ride height and stock camber/alignment settings uses a 8.5 front with ET 51 offset and an 11' rear with ET 46 offset.
That's odd because my stock wheels are ET56 front and ET51 rear.
Old Feb 7, 2011 | 11:52 PM
ruf_turbo's Avatar
Beautiful addition Karim and way better than spacers. Quite a bit more expensive though.
Old Feb 8, 2011 | 01:53 AM
speed21's Avatar
You are right Barry. Sorry, my bad on the stock .1tt offsets. I was going off old diary notes I compliled at the time i was comparing the rf67 rims. My P book for the turbo .1 was was at home....all others in office. I will edit my earlier post, most of which is now no longer relevant and will go and cut my slice of humble pie
Old Feb 8, 2011 | 02:16 AM
k_ddsl's Avatar
Thanks Paul. I'm afraid the wait will be significant... I was quoted 6 to 10 weeks manufacturing lead time!
Any idea how much improvement in performance I should reasonably expect?
Thanks Barry. Yes indeed, quite a bit more expensive I'm afraid.
Although, selling the OEM rims might help offset part of that cost. There's good demand for them from the 997.1 owners over here.
... and will go and cut my slice of humble pie
Hang tough my friend... It's not every day that that happens!!!
Old Feb 8, 2011 | 03:09 AM
speed21's Avatar
Have you considered other alternative offerings or are you firm on these?
There have been a number of wheel threads in recent times and there are some excellent offerings. Now on the performance side of things, i find when i change the stock rims over to the rf67's the car feels a bit friskier to me....unless its just my imagination...or the day..mood or something. But i've heard other lightweight wheel users say they can feel a difference so maybe im not just imagining it. I'll be keen to hear your but dyno impressions.
On the humble pie i will endeavor to make the best out of this rare treat ...if not grimacing just a touch in the eating process .
Old Feb 8, 2011 | 04:39 AM
bumperpip's Avatar
bumperpip is infamous around these parts
Beautiful choice of wheels, Karim. Certainly worth the wait. On the GT board, Pete had a long and illuminating conversation with P's Andreas Preuninger (sp?) in which he (Preuninger) emphasizes P's "obsessive" attention to weight control. If I didn't know better, I'd swear the speaker was Colin Chapman. Add Lightness indeed!
Old Feb 8, 2011 | 04:43 AM
k_ddsl's Avatar
Hey Paulie,
I've been having wet dreams about these rims for a while now, so I guess I'm firm enough that I already placed the order.
Once installed, I'll actually give you more than just butt dyno impressions, I'll make like the friendly sleuths from "Myth Busters" and PBOx the before and after and publish the results here.
Cheers,
Oh! Yeah! Wait! Ehmmm... Bon Appetit!
Old Feb 8, 2011 | 04:46 AM
k_ddsl's Avatar
Thanks bro. And thanks for stating your opinion earlier forcefully yet with a lot of humor!
Go forth and prosper!
Old Feb 8, 2011 | 04:54 AM
speed21's Avatar
Well Karim there is little doubt these are of beautiful quality and appearance so congrats on such a fine selection. Cant wait to see the pics and have your impressions and Pbox confirmation data.
PS. Im still trying to finish my pie.... .
Old Feb 8, 2011 | 05:50 AM
SpunkyQ8's Avatar
SpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond reputeSpunkyQ8 has a reputation beyond repute
Hey Paulie,
Cheers,
Well no more wet dreams for u bro I guess..
Hope to see ur ride running on new shoes.. I might be interested in seeing the results more than u fyi
Gr8 choice made bro applause on that
PelicanParts.com
930 Turbo Vendor Classifieds
Aug 18, 2015 04:01 PM
PelicanParts.com
964
Aug 18, 2015 03:57 PM
PelicanParts.com
964 Turbo
Aug 18, 2015 03:56 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
