ticking on cold start
Old Feb 11, 2011 | 05:41 PM
Abby997TT's Avatar
Abby997TT has a spectacular aura aboutAbby997TT has a spectacular aura aboutAbby997TT has a spectacular aura about
Originally Posted by The Bogg
okay, thanks. Did you pull the fuel pump fuse too?
no problem . I only pulled the fuse for injectors/coilpacks; and the car didn't start while a cranked
Old Feb 11, 2011 | 07:30 PM
The Bogg's Avatar
Noob question - if you pull the fuse, what is it that circulates the oil when you turn the key? I'm thinking that the cylinders only cycle b/c of the spark from the plug so if the fuse is out how does it help the oil to lubricate the cylinder? I should probably mosey on over to howstuffworks.com
Old Feb 11, 2011 | 10:07 PM
speed21's Avatar
Oil pump is mechanical Bogg....gear driven. Starter motor cranks engine, oil pump starts pumping....,Oil pressure begins. The oil pump pressure relief valve then regulates the oil pump pressure.
Old Feb 12, 2011 | 08:32 PM
The Bogg's Avatar
Aha! thanks Paul.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Rguy
Apr 12, 2020 11:11 PM
ModBargains
Audi Vendor Classifieds
Oct 13, 2015 03:45 PM
oo7
Sep 10, 2015 08:08 AM
