Engine Limits vs Power -- Sharing Some Knowledge
Old May 4, 2011 | 06:34 PM
  #196
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
So according to you my car is a time bomb.
I have my car tuned from US tuner putting over 900Nm on the wheels, I drive the car as a weekend toy so I usually abuse it . I have 34k km/s on it 4 sets of tyres if that makes sense. I street race very often from 30 to 300, some times I do this repeatedly, I also drive to the hills on the limits 2nd 3rd gear all the time, I have also changed my PCCB pads due to hard driving and the car drives like a rocket.
LOoOL stop abusing your car and just schedule in future plan the reinforcing kit protomotive have cheers
Old May 4, 2011 | 07:20 PM
  #197
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
Originally Posted by Tom@Champion
Honestly...the biggest cost in a job like this is not the rods themselves. You'll spend somewhere between $250-$300 (EACH) for a good set of rods. The expensive part is the labor to have your engine removed, torn down, rebuilt, re-assembled, and re-installed. It's a very labor intensive process unfortunately. Then the issue becomes "well if I'm in the engine anyway, why not do some head work, etc?" Again parts for some of these upgrades are not that costly...it's really the labor you're paying the most for.
Agreed Tom BUT what one gets back is not just the same engine with stronger rods but a very different feel engine that breathes better, revs better, has more torque etc etc. You get the effects of a blue printed hand built engine and i ve now done it on a 996 and 997 and the engine was 50% better after a rebuilt compared to what was from the factory (even with same components)
Old May 4, 2011 | 07:23 PM
  #198
GT-TT's Avatar
You dont abuse it enough!! With same specs and kms i ve changed pads a whooping 6-8 times on my pccb! You have to driver harder!
Old May 4, 2011 | 11:24 PM
  #199
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I'll try harder
Old May 5, 2011 | 03:39 AM
  #200
Boostholic's Avatar
Boostholic is infamous around these parts
I wish GT RUS chime in here
Old May 5, 2011 | 08:23 AM
  #201
bbywu's Avatar
This is at least the 5th account you've created on this forum, 2nd (by my count) since you have been banned.
bob
Old May 5, 2011 | 10:48 AM
  #202
vrybad's Avatar
vrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant futurevrybad has a brilliant future
Originally Posted by TTdude
I think your right on. Basically, most of what is being discussed has to do with fatique phenomenon, a well known issue with materials under going repeated stress. Google S-N curves and you will get a ton of information. Each metal and geometry will generally have a fatique limit that corresponds to the number of cycles. The greater the stress the less cycles it will take to fatique if you're above the fatique limit. Certain metals like aluminum and magnesium do not have a fatique limit, meaning that the material will eventually fail no matter what after so many cycles (it could be a very very long time). That's why they grounded all those SW Boeing 737s because of metal fatique due to take-offs and landings (cycles). With steel rods, there likely exists a fatique factor that if you stay below, it will NEVER fail no matter how many stress cycles it encounters. For the internals parts of a motor, one would really have to know the fatique limits for each component, piston, rods, crank, etc...I'm sure Porsche knows these numbers. So if I ever plan to jack up the power on my car and keep stock motor, I know that I will probably be on borrowed time. Hopefully, within that time, I will upgrade the various components so I can enjoy a longer cycle time before failure.
That's a good explanation.
Thank you.
Old May 5, 2011 | 10:52 AM
  #203
karlf's Avatar
karlf is infamous around these parts
nice video
Old May 17, 2011 | 07:40 PM
  #204
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Awesome discussion! to throw a little more fuel on the rod limitation argument, I came across a dynojet run of the GT2RS :
http://blogs.insideline.com/straight.../gt2_chart.jpg
We know the VTGs can do way more low end torque, but it looks as if Porsche chose to limit it considerably. Whether its a durability or drivability issue is the question.
Old Jul 25, 2011 | 01:01 AM
  #205
milou's Avatar
I was wondering who offers engine rebuild kit, and what does it cost?
Old May 28, 2013 | 01:00 AM
  #206
Nardo4's Avatar
Nardo4 is infamous around these parts
Thanks for this fantastic thread!
Old Feb 24, 2014 | 06:20 AM
  #207
mtlsp's Avatar
mtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond reputemtlsp has a reputation beyond repute
awesome thread! thx
Old Aug 14, 2014 | 06:17 PM
  #208
Lysoleverywhere's Avatar
Lysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really niceLysoleverywhere is just really nice
Cost?
Cost to rebuild? Many would like to know im sure.
Old Aug 14, 2014 | 06:31 PM
  #209
yumaverick's Avatar
yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !yumaverick Is a GOD !
Depends what you want done
Jun 10, 2017 07:45 PM
vr6tee
Aug 29, 2015 03:52 AM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
Aug 20, 2015 12:17 PM
