Best way to kill understeer?
Old May 13, 2011 | 09:25 AM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Curious what set-up is best suited to get rid of the all wheel drive understeer problem with 997TT's?
Recently I upgraded to to Bilstein Damptronics (SS10's) which have had a tremendous positive affect, however still not entirely satisfied.
Front & rear sway bars with drop links? Other recommendations?
Possible alignment setups?
Old May 13, 2011 | 09:43 AM
lexart's Avatar
lexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond repute
I don't know if there's 'best way' to get rid of understeer. It more of a gradual approach to see what works for you in specific driving application.
In general things to try, from my 'archives' . . .
Higher front tire pressure
Lower rear tire pressure
Larger front tire section
Smaller rear tire section
More negative front camber
More positive rear camber
Softer front springs
Stiffer rear springs
Thinner (weaker) front sway bar
Thicker (stronger) rear sway bar
Weight distribution more rearward
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Rear Gt2 sway bar, bolts up easily in about 30", OEM quality ( approx $200).
Old May 13, 2011 | 10:07 AM
SuncoastRyan's Avatar
SuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to behold
As Gasman said, the rear GT2 sway can help because of it's adjustability...
Here is a link to our website with more details:
http://www.suncoastparts.com/product//GT2RSB.html
Let me know if there is anything else we can help you out with.
Ryan
Suncoast Parts
877-923-1700
ryan@suncoastparts.com
Old May 13, 2011 | 10:27 AM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
Listen to Doug ,best 200+ you ever spend on your car , you don't need to change factory sway bar in front
If you looking for better steering response in front- install adjustable front drop links that are connect to the hub carrier.
Old May 13, 2011 | 10:51 AM
TT Gasman's Avatar
Looks like it may have gone up in price a bit, still better than the aftermarket alternatives IMO.
Old May 13, 2011 | 11:07 AM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Call Mike at RSS.
Old May 13, 2011 | 03:16 PM
Z06...'s Avatar
Z06... is infamous around these parts
Slow down on the way in.
Old May 13, 2011 | 03:35 PM
floridaBMW's Avatar
floridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud offloridaBMW has much to be proud of
And careful with the throttle on the way out.
Ken
Old May 13, 2011 | 03:45 PM
M32911S's Avatar
M32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to beholdM32911S is a splendid one to behold
Rear GT2 sway bar huh. Easy to install from the sounds of it?
Old May 13, 2011 | 03:46 PM
bbywu's Avatar
More negative front camber, stiffer rear sway bar.
bbywu's Avatar
15 minutes. Straight swap.
Old May 13, 2011 | 07:32 PM
TT Surgeon's Avatar
gt2 rear bar
gt3 LCAs ( more neg camber)
adj rear toe links
stock suspension otherwise
Old May 13, 2011 | 07:35 PM
speed21's Avatar
+1. Its amazing what a decent alignment can do.
Also the best solution is a few driving courses at your Porsche advanced driving school to give you a better undertstanding how the 911 car is driven correctly through corners. Without that all the mods in the world are pretty pointless as you'll only increase your chances of writing yourself off.
Old May 14, 2011 | 08:59 AM
Regular at the Proformance racing school (here in the North West) - about 2 per year. Haven't attended a Porsche sanctioned event yet..
Thanks guys! Was thinking of front and rear, but will prob just approach the rear for now. As for rear drop links? Not necessary?
