Uh oh ... no boost ... what happened?
Old May 15, 2011 | 04:40 PM
ThunderRolls's Avatar
ThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to allThunderRolls is a name known to all
I just installed an exhaust system on my 07 turbo yesterday. It's a Fabspeed with 200 cat. The install went flawlessly. Cranked it up several time in the driveway and things seemed to be working in good order. (sounds awesome too!)
So, I decided to take it for a spin and got about a mile down the road and ran the RPM's up to hear it. At about 4,000 RPM there was a loud bang almost like a backfire from the rear and I lost some power. My initial thoughts were that I hadn't tightened something down. I turned around and took it back home and everything is in place. But I have no boost. I hear the turbo spooling up, but it does nothing.
Any thoughts on what might have happened??? I'll be taking it to the shop, but I am a little concerned to say the least ...
Old May 15, 2011 | 05:15 PM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
running fine? just no boost?
Old May 15, 2011 | 05:21 PM
slawek's Avatar
slawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond reputeslawek has a reputation beyond repute
I would first check connections at the intercoolers and turbo valves (plastic tube) next plenum. Probably, something got loose doing the installation.
Old May 15, 2011 | 05:42 PM
I'll check the intercooler hoses. Yes, everything is running fine. No codes, nothing. Just no boost.
Old May 15, 2011 | 06:40 PM
TT Surgeon's Avatar
If you took the bumper off, the IC tubes are probably loose.
Slate997TT's Avatar
Slate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant futureSlate997TT has a brilliant future
$100 intercoolers hoses poped out
Old May 15, 2011 | 06:50 PM
slawek's Avatar
Check also BRV valves connection and double check your exhaust for any leaks.
Old May 15, 2011 | 08:12 PM
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
boost hose
Old May 15, 2011 | 09:12 PM
LOL. It was a boost hose that came off. I'm glad I posted here so I got pointed in the right direction quickly. Thanks guys!
Old May 16, 2011 | 04:28 AM
Serpentene's Avatar
Serpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant futureSerpentene has a brilliant future
C-clamp...tie wrap...rubber band....yeah I know the feeling...
Old May 16, 2011 | 08:53 AM
MorePSiTehBett4's Avatar
MorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really niceMorePSiTehBett4 is just really nice
more like, tbolt, hair spray, safety wire
Old May 16, 2011 | 08:57 AM
CanyonThompson's Avatar
CanyonThompson is infamous around these parts
I'm kind of surprised you didn't get a CEL.
Old May 16, 2011 | 04:29 PM
That's right ... no CEL. I was surprised too. I dialed through the info menu and there were no messages, no red explanation point, etc.
Old May 16, 2011 | 04:31 PM
That's just crazy to me. The DME should have been pissed when it saw no boost. Maybe you just got lucky. HAHA!
Old May 16, 2011 | 04:52 PM
TT Surgeon's Avatar
Usually the ecu recycles every thirty or so miles. May not have driven enough.
