brake rotor help?
Old May 16, 2011 | 12:27 PM
sam12345's Avatar
sam12345 is a splendid one to beholdsam12345 is a splendid one to beholdsam12345 is a splendid one to beholdsam12345 is a splendid one to beholdsam12345 is a splendid one to beholdsam12345 is a splendid one to beholdsam12345 is a splendid one to behold
brake rotor help?
So its been 8 months since i changed my rear brakes and they are already done.
I plan to keep the car for another 2 years so at this rate i will go thru 2 maybe 3 more sets of brakes.
So i was thinking about getting the Girodisc rotors.
Anyone have these? If so what are your thoughts?
Do they truley last 3x as long as stocks?
-Sam
Old May 16, 2011 | 04:10 PM
vduzin12's Avatar
vduzin12 is infamous around these parts
Unless you have driven a ton of miles (>30k) in the last 8 months or heavy tracking, it sounds like a brake issue.
Old May 16, 2011 | 04:31 PM
sam12345's Avatar
well i hate to say due to the morality, but i drive as tho i am on a race track every day lol. So i dont think its a break issue(i go threw rear tires every 5 months or so), in addition i have put atleast 10k miles on the car since the brake change. I also changed my front brakes december-ish.
I am just wondering what makes more sense from an economical, keep changing stock brakes(keeping the car for about 2 more years hopefully) or upgrade to girodisc rotors for 2200 for the set of 4?
Old May 16, 2011 | 04:54 PM
TT Surgeon's Avatar
Keep with the stock, the giros will wear just as quickly.
Old May 17, 2011 | 08:07 AM
dinorocz's Avatar
dinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond reputedinorocz has a reputation beyond repute
this thread is actually very interesting, would love to hear more info on this.... also wondering, which aftermarket brake rotor/pad would most suggest (not interested in spending 6500 on a full kit w/ calipers and all)
Old May 17, 2011 | 08:35 AM
Slik560's Avatar
Slik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond reputeSlik560 has a reputation beyond repute
Dumb question, but what about the front brakes? It sounds like the rears wear faster than the fronts, and if so, that just ain't normal. I may have just read it wrong.
Old May 17, 2011 | 10:27 AM
CanyonThompson's Avatar
CanyonThompson is infamous around these parts
Are you riding the brakes? 8 months is a very short lifespan for rear brakes. I agree with the previous post that you may have a brake issue.
Old May 17, 2011 | 11:18 AM
TT Surgeon's Avatar
If you drive 'hard', the psm kicks in and results in increased rear rotor wear.
Old May 17, 2011 | 01:39 PM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
exactly what Chris said. You are driving to a degree that the PSM is trying to constantly stabilize the extra yaw it is seeing. This happens a lot to not only 997 turbo drivers but also GT3 drivers on the track (even though they swear the GT3 has no PSM!). The key is to drive fast and smooth so your rears won't wear out as quickly.
Old May 17, 2011 | 02:45 PM
sam12345's Avatar
I tend to drive with psm off quite often recently, could this reduce rear brake wear?
Old May 17, 2011 | 03:29 PM
GotBoost?'s Avatar
GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !GotBoost? Is a GOD !
I have Girodisc rotors front and rear. I can't tell you if they last longer or not because I just don't drive the car a lot. What I can tell you is that it bites harder than stock.
Old May 17, 2011 | 03:43 PM
Tony B.'s Avatar
Tony B. is infamous around these parts
Turn off the traction control for everyday reserved driving. Different rotors will not change anything. Track pads with higher friction will make matters worse.
Old May 17, 2011 | 09:02 PM
TT Surgeon's Avatar
I never turn the psm off, even at the track.
Old May 17, 2011 | 09:10 PM
eclou's Avatar
Possibly, but in our cars the PSM is re-initiated as soon as you activate ABS. The key is if you are driving hard enough to pitch the car around, with PSM off you might have an incident which is much more expensive to remedy than a set of rotors
Rguy
Apr 12, 2020 11:11 PM
HIGHcard
Sep 24, 2015 08:09 PM
ECS Tuning - VW
Sep 2, 2015 09:03 AM
