Upgrading 997.1 key stops unwanted trunk opening
Old Nov 8, 2011 | 07:59 PM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
Just completed the mod. Very easy to do. Seems like this will do the trick. Thanks again!!
Old Nov 8, 2011 | 08:08 PM
petporcheman's Avatar
petporcheman is infamous around these parts
i did the modification to the key fob and it works great i was always opening the trunk by mistake. i saw the gen mananger of porsche here i town at the gym and he had no fix but this did the trick
Old Feb 8, 2012 | 03:32 PM
keithcl's Avatar
keithcl is infamous around these parts
Just bought a 997 with the gen 1 key; left the car wide open twice in one week. Couldn't decide whether to go DIY or not and in the end decided to spend the $50 on the part listed earlier in this thread. (Porsche should be making these available free of charge as the original key design is just so bad.) This note is to help anyone else decide in the future by showing what you get for your money.
The part number is 000 043 400 14 (labelled "Reparatursatz Handsender") and I got it from a Porsche dealer as there is one near where I live. I'm attaching a photo with the replacement trunk lid button in place and the original button shown to the left. The benefit of the new button is that the area of the button that activates the trunk lid is recessed whereas on the original button that area is raised. There may be other differences in the internal parts that make a difference too but they are not so obvious.
So far no unwanted activations...
Old Feb 8, 2012 | 07:21 PM
unterdruck's Avatar
unterdruck is just really niceunterdruck is just really niceunterdruck is just really niceunterdruck is just really nice
Thanks for the tip lexart. Works great and so easy to do.
Old Feb 10, 2012 | 06:00 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
Rep added for the DIY. Little flat head popped the key 3 sec with a dremmel till the grid pattern was mostly gone and WALLA.. It actually requires me to hold it for a sec which is exactly what i wanted. took about 2 min to do.
Old Feb 12, 2012 | 02:21 PM
lexart's Avatar
lexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond reputelexart has a reputation beyond repute
Originally Posted by Squat
. . . took about 2 min to do.
You just took the prize for the fastest Porsche DIY - evah!
Old Feb 12, 2012 | 03:29 PM
vaportrail's Avatar
vaportrail is a jewel in the roughvaportrail is a jewel in the roughvaportrail is a jewel in the rough
Originally Posted by ksdprasad
Super idea Sir.
I'm going to try this when I get home tonight! Off topic a bit, but is it possible to configure alarm settings, i.e. sounding of the horn for arm/disarm?
Old Feb 12, 2012 | 05:12 PM
Squat's Avatar
Originally Posted by lexart
You just took the prize for the fastest Porsche DYI - evah!
We have a lab with every precision lab, and It was shorter but I didnt want to seem arrogant
Flat head popped the key dremel for few second back together and it needs to be depressed for a second. Very happy
Old Feb 13, 2012 | 08:59 AM
function12's Avatar
Nope. You just have to look for your lights to flash or listen for the doors to lock. I know on earlier cars you could bend the center console alarm switch out of the way. This would give you a quick honk to let you know there was a fault. I did it on my 04 but have not tried it on my 07tt.
Old Feb 13, 2012 | 01:31 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
Did the quick easy fix on my key and it now works great, no accidental openings. Thanks for the tip!
Old Apr 13, 2012 | 12:28 PM
The Bogg's Avatar
You can save your pennies and do this fix yourself. Each of the fob buttons has a 'pin' that pushes down on the rubber switch membrane between the button and the switch on the electronic board. All is needed is to reduce the hight on the button 'pin' by about 1mm. Just file down the pin. I used my trusty Dremel tool with an abrasive wheel but you can also do this using a small file.
Problem solved!
Thanks again for the tip - rep point for you.
I'd been thinking of doing this for a while. When I'm not wearing a jacket I carry the key in my hand. Left a restaurant today and the key fell out of my hand and broke apart into multiple pieces. Thanks to another thread I was able to figure out where that little spring came from. While the fob was apart I took the dremel to it as per your instructions. Now I won't be afraid to put the key in my pants pocket anymore (fingers crossed).
Old Apr 13, 2012 | 01:13 PM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
I popped up the trunk lid accidentally as well after I get done putting gas and I reach for my keys in my pocket. I usually don't find out about it after I have a warning after I start the car. Annoying.
Twice is enough for me - I will give this a shot when I get back home from my trip.
Thanks for the tips!!!
Jul 29, 2019 11:13 AM
Steven997TT
Aug 27, 2015 02:56 PM
gulf gt
Aug 27, 2015 10:27 AM
