Question for those with the VRT kit
Old Jul 20, 2011 | 06:44 AM
jeh's Avatar
jeh
jeh is infamous around these parts
Does your oil temp rise after the installation of the kit? mine has risen 10 degrees C after the installation of the kit.
the fan was also on for a really long time after just a short drive
Old Jul 20, 2011 | 03:13 PM
vividracing's Avatar
The Vorsteiner aero kit?
Old Jul 21, 2011 | 01:59 AM
jeh's Avatar
jeh
yup, seems like their design doesn't dissipate hot air too well..
do you have the same issue???
Old Jul 21, 2011 | 09:24 AM
Have absolutely no issue at all. What I bet is happening is your air temperature sensor that reads on the dash is behind the bumper as there is no predrilled hole for it.
Old Jul 21, 2011 | 09:31 AM
eclou's Avatar
eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !eclou Is a GOD !
If I understand correctly he is having elevated OIL temps, not the ambient air temp reading. The ambient air temp sensor has no relation to the engine oil temp sensor
Old Jul 21, 2011 | 09:41 AM
misread that...
OP - post pics of your car
Old Jul 21, 2011 | 09:55 AM
jeh's Avatar
jeh
misread that...
looks just like urs! haha.. I will take some and post them tomorrow
Old Jul 21, 2011 | 09:56 AM
The ducts are open wider then OEM so you might have a mechanical issue. Who did you buy the kit from? Sorry your having an issue.
Old Jul 21, 2011 | 11:14 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Don't want to hijack this thread but speaking about the ambient temp sensor, I have had some real strange behavior lately. I've noticed on a few occasions that it is about 10 deg Celsius higher than it should be. Once I was cruising (not throttling) and it spiked to around 40 deg C, after which it started to settle down again. Would this be a faulty sensor - or something blocking obstructing the flow? Any way to check? Have no clue where it is.
I'm running stock bumper with TechArt bottom spoiler lip.
Old Jul 22, 2011 | 01:14 AM
hypers09's Avatar
hypers09 is infamous around these parts
Just wanted to say that I have had no issues with my car... If you should have any questions you should contact Andreas at Vorsteiner I know he would be more than happy to help out.
Old Jul 22, 2011 | 04:10 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Not sure where your located but it has been extremely hot here in NY. Like over 95 plus every day. Perhaps it is the extreem temp not the kit? Good luck
COBB Tuning
Jan 1, 2025 09:02 AM
Aug 21, 2015 06:34 AM
Aug 19, 2015 06:55 PM
Nissan GTR
Aug 19, 2015 02:11 PM
