Sponsored by: Bears Transport
GT3 Brake Ducts - Not So Great? (pics)
Old 02-28-2013, 01:18 PM
rvhpno80's Avatar
rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !rvhpno80 Is a GOD !
Thanks for the pics, very good to know...
Old 08-21-2014, 04:27 PM
sidwin's Avatar
sidwin is on a distinguished road
Great pics. I'll put mine on.
Old 08-21-2014, 08:04 PM
pwdrhound's Avatar
The stock GT3 brake ducts are pretty useless as they are a secondary cooling item on the GT3 where primary brake cooling is provided by radiator air being diverted over the brakes via the upper air guides. If you want good brake cooling swap out to those and the GT3 fender liners
Old 04-06-2019, 03:51 PM
eturk's Avatar
eturk is an unknown quantity at this point
Notch for steering tie rod?
Always wonder if I should ask in an old thread that's on topic or start a new?
I'm replacing mine and notice the circular cutout at the top do the steering tie rod will clear on compression. See pics above comparing.
The stock cutout means about 1" more clearance before hitting the tie rod on a big bump. It's a rigid plastic & probably not good hitting rod.
You guys didn't cut it out to match?
You guys didn't cut it out?
alevine
11-04-2015 10:05 AM
TrackOne
08-20-2015 12:56 PM
Vrseis
08-20-2015 07:41 AM
pwdrhound
08-20-2015 05:54 AM
Quick Reply: GT3 Brake Ducts - Not So Great? (pics)
