First gear sucks on 997 tip
Old Aug 26, 2011 | 04:56 PM
MK23's Avatar
MK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud ofMK23 has much to be proud of
Im sure you tip owners have felt the ridiculous lag when you mash the pedal at a light and sit their waiting for a second or two for the car to turn into a Porsche Turbo I did a search on the forum about the anemic nature of the tip from 1st gear till 2nd when you floor it but didn't find any solutions. Besides brake torquing, is there any way to get the car to jump out of the gate? (and yes I know this is bad for the car repeatedly but once in a while is ok, right?) Does an ECU tune "fix" this problem?
Old Aug 26, 2011 | 06:05 PM
Fnulli997tt's Avatar
Fnulli997tt is infamous around these parts
Great question, I'm listening as well...
Old Aug 26, 2011 | 07:33 PM
hed's Avatar
hed
hed is a jewel in the roughhed is a jewel in the roughhed is a jewel in the rough
My car's take off is anemic if I leave it in auto mode as the car starts off in second by default. So I go to manual mode and start off in 1st, the car will automatically shift the gear at red line, makes for an improvement as compared to letting the automatic handle it. This is for a standard line take off. It's not worlds better, just improved. My understanding is a ECU/TCU upgrade along with an exhaust upgrade does help the car improve take off in the lower RPM range..
Old Aug 26, 2011 | 10:00 PM
Norman75's Avatar
Norman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really niceNorman75 is just really nice
If I start in first gear my car flies off the line. It's a bit of a pain though to get it on first gear in auto. Got to put it in first gear in manual then put it back in auto sport mode. If you were driving aggressively prior to stop and were in sport mode the gear will be in first automatically when you stop.
Old Aug 27, 2011 | 01:53 AM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
Hey Fellas, I have had some experience/ small problems along the way with my trans build on my tiptronic- Through out step by step mods including TCU tuning for faster/harder shifts, as well as upgraded clutch packs are mods that help built stability in my trans for 800+whp... But it wasnt till the 3rd time the car was in the shop for a leaky trans, I decided to upgrade the torque converter... Upgraded torque converters benefit off the line by having the car engaging slightly higher in the rpm , so its already in boost and your off.
Old Aug 27, 2011 | 08:56 AM
kw911TT's Avatar
kw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud ofkw911TT has much to be proud of
I'm guessing you are not talking about the PDK? I don't feel anemic with my tip.
Old Aug 27, 2011 | 08:59 PM
DJ23's Avatar
DJ23 is a jewel in the roughDJ23 is a jewel in the roughDJ23 is a jewel in the rough
I have the PDK and in first gear, especially in sport mode my car roars out from a dead stop. And this is in manual or auto mode.
Old Aug 27, 2011 | 09:13 PM
salerno713's Avatar
Hey PDK owners... SCRAM- I think he is talking about his 07' Tiptronic
Old Aug 27, 2011 | 09:24 PM
NorCal510's Avatar
NorCal510 is infamous around these parts
Shoulda bought a manual instead....
Old Aug 27, 2011 | 09:30 PM
gerbs's Avatar
gerbs is a jewel in the roughgerbs is a jewel in the roughgerbs is a jewel in the roughgerbs is a jewel in the rough
Old Aug 27, 2011 | 09:42 PM
gt2urbo's Avatar
gt2urbo is infamous around these partsgt2urbo is infamous around these parts
brake boost. hold brakes down. then hit gas to around 4k rpm. let go of brake.
Old Aug 27, 2011 | 09:44 PM
salerno713's Avatar
Yes! Launch control 101. Just try to let the Tiptronic cool off inbetween hard launches, they tend to get hot really quick... And eventually slipping with higher HP/modded turbos.
Old Aug 27, 2011 | 11:51 PM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
No pain at all, just put on sport mode and the car launches in 1st gear by it's self.
You can do 100s of launches (not using the brake) sport mode 1st gear with no problem. I do 5-6 launches one after the other, no problem.
The problem is when brake boosting when car is stopped.
I think torque converter when modified will engage earlier and launch faster, but then it might be less reliable for every day use, best thing is to use brake a little 1500rpm and let go, no need to brake boost till turbos kick In. This will give you a better launch without harm on the tip
Give it a try
Old Aug 28, 2011 | 01:24 AM
MK23's Avatar
Thanks! I don't know what part of "Tip" and "07" people are missing!!
Yes, PDK is the greatest thing since sliced bread. But for those of us lowly 997.1 Tip owners, any advice on getting granny out of the gate would be appreciated!
Old Aug 28, 2011 | 01:27 AM
MK23's Avatar
Give it a try
Thanks, I'll try that. I've done some brake torquing up to 3000 rpm but have always been afraid of breaking something. And yes, the manuals definately launch better but I bought the tip believing the magazines and porsche itself that the 0-60 is anywhere between 3.4-3.7 seconds--faster than manual. But I don't know how they get those figures unless they are brake torquing the car to death!
