First gear sucks on 997 tip
Artem evo - you did 1 too many launches my friend, the clutch packs inside the transmission seem to be fried which is causing slippage. This happened to me at 30k miles with my 700 kit on it (lots of abuse). Is there any Trans fluid leaking? If not its possible your tcu can not be tuned properly.
ther's a tip
when the tip becomes slipping you will see crazy rpm rising till the red zone.here we can see that the tip can't go with rpm higher for one or two seconds.can somebody tells me ?may be it is injectors works not fully correct ?
tranny is without any leaks .
some guys tell me that that jumping can cause 19"toyo tires-but at the other calibrations it went good.
I tried with 17" the same problem.even without boosting.
or it can be the suspension problems.
But I reallky dont know how it can cause that problems.
I think too or injectors or tcu module.
Do you fix your problem?
Oct 6, 2015 03:43 PM
