Clutch or not
Old Aug 30, 2011 | 10:38 PM
jdavis911's Avatar
jdavis911 is infamous around these parts
Clutch or not
I've posted earlier about my slipping clutch and received great answers. Knowing I need a new clutch I've been babying the car a bit till I find the time. The car will stall on a 4 gear start and will slip on a hard pull in 5th gear at low rpm and slips sometimes on a hard dig from first to second Well it use too then it stopped for a couple of weeks I couldn't get it to slip at all, quite happy I continued to drive the car as normal maybe 7/10ths daily driving. Well this morning it's back and slipping hard 4th 5th 6th, so need a clutch. Weird thing drive home and now I can't get it to slip. The car was cold each time any explanation, is there any adjustment on these clutches?could I have a leak only sometimes?
I guess at the end of the day I would prefer to not do a clutch, however if I do I'll ad a Sachs and a tune which isn't so bad.
Old Aug 31, 2011 | 10:36 AM
SpoolnV8's Avatar
SpoolnV8 is infamous around these parts
Swap to a GT2 slave cylinder and the car wont slip on a lauch or the 1-2 shift... As far as Putting power to it under a heavy load, 4th, 5th, 6th. Just downshift and avoid that big torque hit. Then you can avoid a $4000 job.
ECS Tuning - BMW
Sep 16, 2015 07:20 AM
Blue Chip
Sep 10, 2015 07:07 AM
ECS Tuning - VW
Sep 9, 2015 03:11 PM
ECS Tuning - VW
Sep 9, 2015 12:01 PM
ECS Tuning - VW
Sep 3, 2015 09:43 AM
