911 TTS Cabrio Winter Tips for a Newbie
Old Oct 5, 2011 | 05:45 AM
Wilson's Avatar
Wilson is infamous around these parts
When I broke my left ankle mine sat from august to december with only one or two drives. It was just fine, a little dusty on the outside and once I had fresh gas and oil in it it felt like new, although I couldn't tell a difference even before those things.
Sounds like you will get out for a drive on a nice dry day so I really wouldn't worry too much, especially since its such a new car.
Old Oct 5, 2011 | 06:05 AM
SuncoastRyan's Avatar
SuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to beholdSuncoastRyan is a splendid one to behold
Originally Posted by JSF721
By service you mean Oil? I got the car in March and am embarassed to say the car has 500 miles on it. Still get the oil changed?
If that is the case, you probably do not need to do a service on it...
Ryan
Suncoast Parts
877-923-1700
ryan@suncoastparts.com
Old Oct 5, 2011 | 07:55 AM
SKYKING's Avatar
SKYKING is a name known to allSKYKING is a name known to allSKYKING is a name known to allSKYKING is a name known to allSKYKING is a name known to allSKYKING is a name known to all
If you do take it out for a drive around the block, I strongly suggest you drive it longer than around the block. You should bring it up to operating temps, oil and water, and then drive it for at least a half hour or more. Once you start the car, moisture builds up inside the engine, it usually takes thirty to fifty minutes to evaporate the moisture. If you do not get the moisture out it will corrode the inside of the engine.
Once you prepare the car for storage, it is best to not start it or drive it unless you can drive it as stated above.
I also recommend you put a few large size desiccant packs inside to reduce moisture.
Remember, if you stop your liability insurance call your salesman and tell him to reinstate it for the drive.
Old Oct 5, 2011 | 08:17 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Thanks, I will make sure I can drive for an hour if I take it out. I also plan on keeping the insuance in force over the winter. What is considered a "large size" desicant sack? Any where to buy them.
Old Oct 5, 2011 | 09:50 AM
SKYKING's Avatar
They are available from Fasenal :
http://www.fastenal.com/web/products/detail.ex?sku=0600788&ucst=t
Many stores in NY.
Cheers
Old Oct 5, 2011 | 10:37 PM
jdavis911's Avatar
jdavis911 is infamous around these parts
Before putting my boat away I do my annual oil change, according to my mechanic the old oil holds more moisture and contaminants and left sitting will lead to excess corrosion over the winter. I do this whether the boat needs one based on hours or not.
AUDIRS6
11
Oct 8, 2015 12:21 PM
DaButcher
New Member Introductions
Sep 16, 2015 02:49 AM
richard181
Bentley
Sep 9, 2015 01:53 PM
ppwchiang
Aug 20, 2015 10:28 AM
