Intercoolers...
Old Nov 5, 2011 | 12:41 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
TTdude, my nozzles are in the IC outlets. Agree that there may be a flash cooling effect if droplets sit on the IAT sensor. I'll see a quick IAT drop at the initial hit, then IATs increase but at a lower slope so it appears the sensor is still doing it job (i.e it doesn't just sit still at some low IAT).
Old Nov 5, 2011 | 02:04 PM
cannga's Avatar
Originally Posted by bbywu
True, although it is small compared to the black hole that RS Tuning will leave you.
Did you get the name of that company wrong? I thought it is R$ Tuning$$$$??
The 4 plural s at the end signifies the minimum number of engine dynos required to make a Schmirler tuned car runs correctly.
There is a RR Tuning GT2 limping around Europe somewhere and when I asked why it runs so poorly, the explanation was that Reinhold Schmirler needs to "fine tune$$$$ " it personally for it to work properly!
Old Nov 5, 2011 | 02:58 PM
GT-TT's Avatar
GT-TT is infamous around these partsGT-TT is infamous around these parts
gt2 expansion intake for up to 670hp. That will give you another -10/15 degrees if someone can tune it properly.
Old Nov 5, 2011 | 03:57 PM
SVTHorsnake's Avatar
SVTHorsnake is infamous around these partsSVTHorsnake is infamous around these parts
Is spraying methanol on the exterior of the IC not a popular method for TTs? We used to do it on Fords, and STis came with it that way. It might not be as effective but there's no risk of getting a skewed reading from the IAT.
IMO methanol is a bit of an unreliable crutch. It's a strained risk for not a lot of gain. I live at 5500 ft elevation though, so I guess you coastal folks might be forced to get creative with manipulating air temps.
Old Nov 5, 2011 | 06:22 PM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Thxs guys for answers,
I understand water/meth injection is the must, if I can't find better parts than mine it would be the next step, going to speak my wife about holidays in Turquey! (Arkansas is truly too far by car, even in a fast 997TT!)
Old Nov 5, 2011 | 09:06 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Holiday in Turkey. I like that. I'm sure your wife will love to see beautiful Turkish Porsche shop--lol. I took holiday to Arkansas by myself. More fun--lol.
I think meth injection is your best option. You'll get lower IATs plus higher octane. Otherwise, change your turbos.
Old Nov 6, 2011 | 03:04 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello Pascal,
You are more then welcome here.
We have very nice restaurants, shops and the Bosphorus... too much too see here, i'm sure your wife will love it too.
Regarding the intercoolers, we have tested every brand here, the best solution is water/meth injection.
It will cool down intake temp and it will boost your octane level.
We have installed more than 18 kits here, most of them were Porsche's.
Its really the way to go.
There is also one more trick that you can do.
We have produced bigger air ducts for the intercoolers.
They are like the GT2RS but wider to get more air. You can see them in the pictures below.
Old Nov 6, 2011 | 06:45 AM
GT-TT's Avatar
emre do you need new programming for the meth kit?
Also what are the drawbacks?
Old Nov 6, 2011 | 12:28 PM
K24F's Avatar
Some things are moving guys
The Saudi Arabia Protomotive dealer offers me to do the logs I need on his cars! Great!
But perhap's I will log myself other AM Ics too, some great brand seems ok to send one set!
It is possible there is no IC able to hold tuned metzger IATs on long pulls, perhap's because of the implantation in the car more than the quality of the Ics.
I think I will know it...
Emre: thxs for the pics, I think it is a little step more to cooling, but not enough I'm afraid.
How many hours does it need to bolt an Aquamist on a 997TT? That would be my last step if the best Ics available (at correct price) on the market aren't efficient enough...
Old Nov 7, 2011 | 03:40 AM
It's not a must, but you should re-tune your car to get the maximum gain.
(AFR, ignition timing etc..)
There isn't any actual drawback that i have seen yet,
but proper installation and setting the system is very important.
What octane do you normally use?
What are your intake temps @WOT?
Old Nov 7, 2011 | 03:47 AM
Installation should take about ~6 hours.
Which y-pipe do you use?
Old Nov 7, 2011 | 05:36 AM
GT-TT's Avatar
Rebuilt engine with cams rods, etc etc with large gt2 VTgs and expansion intake (the one that none except my tuner likes!) making 740hp /950nm. Logging at 23 ambient around 52 max IATs (probably lower than 50 without an air leak i had). At 10 ambient logging around 37. All measurements to 300kms per hour with gt2 rs coolers. Have a simple water spray system for the ics, but not sure how much this contributes. I think the expansion intake is the trick with VTgs for up to my power level. But none seems to want to believe this.
100-200 in 5sec, 100-300 16.8 with passenger. All ecu safeties are on. Pump fuel 100 oct but really bad quality in Greece these days..
Have you tested those inlets you posted above Emre? Do they make a measurable difference?
Old Nov 7, 2011 | 06:05 AM
K24F's Avatar
Stock one
Old Nov 7, 2011 | 01:50 PM
997tttiplux's Avatar
997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute
Hi P. and all
My little contribution on the subject about the quality of the Aquamist products: don't forget that they started their business designing and building WMI kits for WRC rally teams (Ford at the begining if my memory serves me right), so I think they're really good and now experienced at what they're doing and selling.
P. If you happen to come up here north, I'll be pleased to show you mine.
David
Old Nov 7, 2011 | 02:17 PM
PERONE78's Avatar
PERONE78 is a jewel in the roughPERONE78 is a jewel in the roughPERONE78 is a jewel in the rough
Hello Pascal,
Emre I want buy immediately the air ducts, after I sell my EVOMS kit (I hope in few days), I buy from you another turbo kit and meth inj. You are the best!
