Motor Upgrade Begins
Nice. I probably didn't need to put it in hibernation this year since there's been so little snow but at least it helps build some anticipation of spring! Got some goodies on the way (GT2 side sills, carbon rear wing (upper part), hopefully some Vivid DRLs, GMG springs and sways) so I'm definitely stoked about spring and the car.
am thinking to send my GT3076 turbos to install the HTA wheels
Nice. I think those are supposed to hit harder than the alphas but possibly be surgier? You get more flow up top too if I remember correctly. Post some details of your build when it starts. Folks here would be interested.
Tt dude ?.???
I have my car at protec . I'm doing the motor and big turbo upgrade like u .
I'm doing e .85 3076 and. As far motor I'm doing rods rings springs 12 mm studs .
My question is would u do 3.6 liter build like i described above and ad cams.
Or
Just go all out and do a 4liter build for diff of 9k more. And would be 4liter with heads and cam.
Or
Hey Motion--I just took out the sleeves so I'm at a decision point. Not sure I can afford new liners/pistons. If you go 4L then you might reconsider getting bigger turbos, especially on e85. I assume you're going to do 3.8? That would be an easy conversion. Have you talked to Keith? Which headstuds are you using, Evoms? Good luck with your build. Post some pics/updates.
Or
Or
Yes they will . you may have to buy caliper brackets from porsche. For 150 bucks
Where are you getting the work done? I see you r in Montreal, just wondering if you're using someone local.
