Sponsored by: Bears Transport
Driveshaft Guibo
Old 06-01-2013, 01:38 PM
The Bogg's Avatar
Originally Posted by speed21
Q. What is the symptom of a worn flex disc in operation? Also symptom of worn driveshaft/or half shaft, that is on the way out.....without visually inspecting?
Tks.
Apparently a bit of noise or vibration, and if it is really bad there will be clunks. Just saw the pics of mine and it definitely looks worn out. Getting one off ebay today.
Old 06-01-2013, 04:48 PM
speed21's Avatar
Like to see the pics if you don't mind. Also when does the clunk you speak of occur? Is it all the time or, just between shifting after releasing the clutch and re applying the power?
Old 06-01-2013, 06:16 PM
The Bogg's Avatar
The guy showed me the pics on his iphone so I don't have a copy. But if you google "broken driveshaft guibo" it will show pictures where there is a tear/crack in the rubber and that's what mine looks like, lol.
I'm not sure when and how the noises occur, but I think visual inspection is the first step and should be routine every couple of oil changes from what I've read. I know I'll get things checked more closely b/c it would be much more costly if it actually broke and caused damage.
Old 06-01-2013, 06:18 PM
The Bogg's Avatar
Oh just to clarify, I don't think I'm personally experiencing any clunks or thunks related to the guibo.
Old 06-01-2013, 06:21 PM
speed21's Avatar
uha. So no tell tale signs in operation to speak of then......just a visual inspection thing showed there was an issue with the rubber eh? Just that i saw in your other thread the mention of whines and clunks or something going on so thought id check on what the actual signs of this thing failing are. Surely must be some give away signs?
vr6tee
09-16-2016 10:41 AM
Glasgo
11-30-2015 02:37 PM
WheelsupZR1
09-19-2015 06:46 AM
Quick Reply: Driveshaft Guibo
