Battery Replacement Advice
Old Jan 8, 2012 | 02:18 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
My 2007 997.1 Turbo needs a new battery.
If I replace it myself, do I need the Porsche dealer to reset anything? Car is bone stock. Any unique issues to the battery replacement?
Fellow owners spoke highly of the Walmart Battery MAXX-94R for $80. Any other suggestions? If so, please provide make and model #. Thanks for your advice on this
Old Jan 8, 2012 | 02:36 PM
John in Norcal's Avatar
John in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to beholdJohn in Norcal is a splendid one to behold
Recently replaced my battery with the Wal-Mart battery. Perfect fit ...even the factory vent tube plugs right into the Wal-Mart battery. If you have a batter maintainer, plug that into the cigarette lighter socket before taking the old battery out. That should keep all electronic components from needing a reset.
Old Jan 8, 2012 | 03:36 PM
aviography's Avatar
aviography is infamous around these parts
Just make sure you have the radio code handy.
Old Jan 9, 2012 | 01:29 PM
stvs911tts's Avatar
stvs911tts is infamous around these parts
Where is that obtained from?
Old Jan 9, 2012 | 01:43 PM
jhbrennan's Avatar
997's don't have radio codes.
Old Jan 9, 2012 | 02:41 PM
Doc GTO's Avatar
Doc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond reputeDoc GTO has a reputation beyond repute
On my last 997I used an Interstate battery but there are only a few companies that make them. Johnson Controls makes/owns Interstate, Optima, Autozone brand, Walmart brand, ect.
Old Jan 9, 2012 | 02:47 PM
hroussard's Avatar
hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !hroussard Is a GOD !
Interstate
Just replaces mine. My shop recommends Interstate. I think the model is 930 ( not sure) . I paid 134 dollars including installation etc . This battery has the little tube as required by Porsche to evacuate the fumes. It has 48 months pro-rata warranty.
Old Jan 9, 2012 | 03:21 PM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
My airbag light came on after i changed the battery so how do i reset that ?
Old Jan 9, 2012 | 03:51 PM
hjacobs2000's Avatar
hjacobs2000 is infamous around these parts
Drive it for about 15 minutes and it will reset itself
Old Jan 9, 2012 | 04:07 PM
997TTurbo's Avatar
Thanks for all the advice. Ended up getting an Interstate battery,
#MTP-94R, came with a 85 month warranty and cost $160. The Walmart battery was $110 but only had a 36 month warranty so it made sense to get the Interstate. It is the exact same size and had the venting hole for the Porsche OEM vent tube that was connected to the stock battery I took out.
Be aware of the order of removing the old battery and connecting the new battery to avoid frying your electronics! When removing the old battery, remove negative cable first, then then positive cable second. When connecting the new battery, it is the opposite-connect the positive cable first and then the negative cable. On my 2007 997.1, the positive cable was marked with red and it was on the left side of the battery as you look at the installed battery head on. The negative cable was on the right side as you look at the installed battery head on.
I was amazed that I didn't need to reset anything...the PSM failure light came on but went away after 3 minutes of driving. All my radio stations and pre-set memory seats were OK too. I did have a battery tender in the cig lighter while I was doing everything so maybe that saved some information, don't know.
Old Dec 18, 2017 | 04:24 PM
BOXER12's Avatar
BOXER12 is infamous around these parts
H8
my 997.2 TTS is a size H8. Walmart Maxx (made in Germany) was $123. Interstate MT-49 was quoted at $297.
Old Dec 18, 2017 | 09:43 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
No need to worry. Just swap out and drive. No resetting anything.
Old Dec 22, 2017 | 08:24 AM
I use Bosch Platinum 94R800BAGM sold at Pep Boys
#TeamAIM
Old Jan 1, 2018 | 08:06 PM
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
I use the same Bosch from Pep Boys....oh and nice 5 year old thread necro guys
Old Jan 2, 2018 | 11:49 AM
for sure lol - but info still relevant today
#TeamAIM
pwdrhound
Sep 16, 2021 02:27 PM
Jul 29, 2019 11:13 AM
DetomasoGTS74
Nov 11, 2015 09:01 AM
OldBoldPilot
Aug 24, 2015 04:00 PM
DSCOFF
Aug 23, 2015 01:22 PM
