Power potential of a 997.1TT with bolt on parts...
Old Feb 15, 2012 | 01:32 PM
  #46
awesome82's Avatar
awesome82 is a splendid one to beholdawesome82 is a splendid one to beholdawesome82 is a splendid one to beholdawesome82 is a splendid one to beholdawesome82 is a splendid one to beholdawesome82 is a splendid one to beholdawesome82 is a splendid one to behold
Originally Posted by edelectra
With vgts you can get away with just changing injectors . the stock pumps run out a lil over 600 whp on e85 . whats on your mind joe lol
not for me.. bros got a 997T and he is thinking of going to do a VTG upgrade. (only current mod is turbo back straight pipe and tune) Im pushing him to tune it with E85 and 93 if that's possible. I know my car has multiple maps i can run depending on fuel but im not familiar with the porsche tuning.
He does daily the car but not far. He would mainly put it on E85 when hes knows hes going to run it hard so map changing via a laptop would not be an issue
Down the road he plans on intercoolers and Y pipe but just cant do it yet
Old Feb 15, 2012 | 01:48 PM
  #47
edelectra's Avatar
edelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond reputeedelectra has a reputation beyond repute
You cant do that because of injector size . Switzer is working on somthing that will allow that I think . maybe he can chime in.
Old Feb 15, 2012 | 03:29 PM
  #48
Slick997's Avatar
Slick997 is infamous around these parts
Originally Posted by Tom@Champion
I have to agree with Tiago on this one Lou. In our experience, a stock 480 Crank HP turbo will put down about 420-430 at the wheels, depending on the type of dyno used. With a good exhaust system and ECU flash, you would see approximately 70-80 hp at the wheels increase, which puts you around 500 at the wheels.
From there, intercoolers, y-pipes, larger TB and plenum will yield nominal increases in power and definite improvements in consistency, but nothing close to 600 at the wheels, I just don't think that's possible.
Our 65mm Billet VTG's, which are probably the largest flowing 65mm VTG's out there, will yield 600 at the wheels on pump gas, a little more on race fuel. To get that without turbos is just not possible. The stock turbos just can't possibly flow that much.
My yellow switzer vgt700 tip car was only making 560awhp and ripied off a 136mph 10.8. So we all know what dyno,s are good for.
Old Feb 15, 2012 | 03:53 PM
  #49
Slick997's Avatar
Originally Posted by Mike/AWE
Jdmuscle,
I see you are from NY. Our company is located two hours south of NYC.
We are full service late model Porsche tuner focusing on the Turbo models. We have a Mustang Chassis Dyno, onsite Fabrication, install capability, and a direct line to GIAC for software needs. Anything you have read in this thread, we can do. From wheels spacers all the way up to 750hp turbo kits.
If you don't mind, shoot me an email with your phone number. I would like to call and discuss our services.
Mike@AWE-Tuning.com
I look forward to hearing from you.
My budy Avo at Toys autoart sells your 700hp kits, and i must say there amazing also, seen a few of them that he did with your kit,s. Realy nice and easy install.
Old Feb 15, 2012 | 06:18 PM
  #50
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
How about an Aquamist Meth system ; since were talking modded VTGs that are off the shelf- essentially a bolt on.
Just depends how far you want to go..- CMS offers a 68mm VTG kit is rated @495hp per turbo and with enough fueling your quickly at the limit of this motor
Old Feb 15, 2012 | 06:55 PM
  #51
venkatreddytx's Avatar
venkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond reputevenkatreddytx has a reputation beyond repute
You need to upgrade to 83lbs injectors from factory 60lbs injectors to run E85.
Todd gives you 93Oct tune and a E85 tune, you need to flash to tune based on fuel being used.
Old Feb 15, 2012 | 08:04 PM
  #52
edelectra's Avatar
Your correct I mis read his post. I was thinking fuel sensing maps
Old Feb 16, 2012 | 07:55 AM
  #53
awesome82's Avatar
thank you.. this is prob his best option as the car will run 93 most the time and e85 sometimes
Ed.. if he wants to go this route, i will give u a call to discuss
Old Feb 18, 2012 | 04:34 PM
  #54
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
Originally Posted by Jdmuscle
Hello Gents... I am wondering what a 997.1TT is capable of with bolt on parts without changing the turbos or any involving modifications.
For instance, I am looking for what can this car do with the following parts:
- Exhaust
- Tune
- Headers
- Intake
- Other minor things that can increase the power potential without breaking the bank.
Please pardon me if this topic has been discussed many many times before ... I searched and didn't come across the information I am looking for.
Thank you much in advance for your information.
U need also to check PE750 and TPC750 kits also
Jun 10, 2017 07:45 PM
97GtsMonster
Nov 17, 2015 12:38 PM
Ferrari
Aug 24, 2015 04:35 PM
