Check Engine light on because of fab speed cats
Old Jan 24, 2012 | 02:26 PM
Izwar's Avatar
Izwar is infamous around these parts
Hey i bought my turbo about 4 months ago and its always had the check engine light on and the small red exclamation mark on as well, i took it into the shop a few times and they cant get it to turn off, if you reset the comp and what not it will go away for a few days but it will turn back on. THen randomly it will go away again but always return eventually.
I have the fab speed high flow cats and there cat back exhaust on the car that i bought it with so im guessing that can be the only reason for it, any solution to solve this as i might be sellin the car soon and i cant sell it if the check engine light and other light is always on lol either that or i go back to fully stock set up which would be annoying
Old Jan 24, 2012 | 03:48 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Get the turbo flashed and permantly get rid of the CEL being thrown by the cats.
Old Jan 24, 2012 | 04:12 PM
cay-man-ess23's Avatar
cay-man-ess23 is infamous around these parts
Aftermarket exhausts and cats can cause havoc on Turbo. . . naturally aspirated P cars do fine but Turbo's it throws sensors off normally. . . . get used to lighting up your dashboard like Christmas!
Old Jan 24, 2012 | 05:17 PM
gmoney's Avatar
easily fixed with a flash. You can also try o2 eliminators from bid daddy (google it), you need those mini cat style, not simply extensions as they dont work 100%.
Old Jan 24, 2012 | 06:17 PM
ERSKATEDOC's Avatar
ERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to beholdERSKATEDOC is a splendid one to behold
Bid Daddies will help
I put the big daddies bung extensions on my aftermarket exhaust and CEL's gone (2008 997.1 tt).
They really work.
Old Jan 24, 2012 | 10:23 PM
Izwar's Avatar
i took it do the dealership and they reflashed my ECU went away but came back is that what your referring to?
Old Jan 24, 2012 | 10:27 PM
Izwar's Avatar
Hey guys is this the exact one i would need?
http://www.bigdaddiesgarage.com/mini-cat-cel-fix.html
i have a 2007 997.1 TT
Also i buy 2 right? sorry stupid question.
Old Jan 24, 2012 | 10:45 PM
Turbo Fanatic's Avatar
yep. With those 02 spacers (make sure you install them on the sensors after the cat) there will be no more check engine light. No re-flash required. You need the sensors BEFORE the cats to be in stock position or your car won't run right.
That said, a working aftermarket cat should not throw a check engine light...
Old Jan 26, 2012 | 02:00 PM
Izwar's Avatar
Thanks! jus ordered 2 how much should i be paying for installation on this to get an idea
Old Jan 26, 2012 | 06:24 PM
drsullivan's Avatar
Sorry. I was referring to stage 2 flashing the ECU. The CEL for the triggered post cat sensor could be eliminated. Sounds like things are getting corrected - good luck.
Old Jan 26, 2012 | 07:38 PM
OneFastBeast's Avatar
OneFastBeast is infamous around these parts
Call FabSpeed they have O2 sensors extensions. I did it and got rid of the check engine light!
Old Jan 30, 2012 | 08:47 PM
Fabspeed Motorsport's Avatar
Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !Fabspeed Motorsport Is a GOD !
Hey Izwar, it shouldn't have a CE light as long as it has our new HJS sport Cats. Shoot me a PM with your information or give me a call and we can go over it. We have replacement HJS sport cats for it, so you wont need to use an extenders if the sport cats are good.
thanks guys,
tropicatango
Jun 8, 2025 01:00 PM
COBB Tuning
Jan 1, 2025 09:02 AM
Mini George
Jul 29, 2019 12:20 PM
Nissan GTR
Aug 19, 2015 02:11 PM
