Strange dot on speedometer
Old Feb 8, 2012 | 07:35 PM
sbkim's Avatar
sbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond reputesbkim has a reputation beyond repute
It's more of annoyance then a problem but I just noticed a small dot (deal pixels?) right below the red needle on my tachometer that is lit at all times. Anyone else experience this? I presume the only fix is to replace the display unit?
Old Feb 8, 2012 | 08:25 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Looks like a bad pixil.
Old Feb 8, 2012 | 08:46 PM
iPhoneEngineer's Avatar
iPhoneEngineer is infamous around these parts
Indeed, almost certainly a "stuck" pixel. It is sometimes possible to fix these by careful "massaging" of the area (I'm not kidding). Do some Google searches on how to fix stuck / dead (separate conditions) pixels. The attempted fix is similar, but I think the success rate is higher for one or the other.
Usually, the problem is that one of the connections that controls power flow to the liquid crystal cell is either barely severed, or accidentally shorted, so physical force is sometimes able to push the delicate wiring back into place.
Old Feb 8, 2012 | 08:52 PM
thebland's Avatar
thebland is just really nicethebland is just really nicethebland is just really nicethebland is just really nice
I have a DLP and though this isn't a DLP projector, its going to likely stay on for life.
Likely have to replace the display.
Old Feb 8, 2012 | 09:20 PM
joecmess's Avatar
joecmess is infamous around these parts
had the same thing. Dealer replaced display.
Old Feb 8, 2012 | 09:23 PM
Yeah, assuming you're under warranty, don't bother--it should qualify for replacement. It's definitely not a DLP which would not be fixable in a similar way.
If you end up in a similar situation with an LCD without a warranty, the technique I mentioned can be useful.
Old Feb 9, 2012 | 06:53 AM
sbkim's Avatar
Thanks so much guys. The car is still under factory warranty so I will take it in. I thought about "massaging" the area but you can't really get to easily with the protective/glare plastic guard in front.
agentsmurf
Cayenne 955/957
Oct 17, 2015 02:10 AM
SteveH
Oct 6, 2015 10:05 AM
Mz3bo
Oct 1, 2015 06:32 PM
nagual911
Oct 1, 2015 01:52 AM
PelicanParts.com
Sep 25, 2015 03:17 PM
