battery on 997.1tt
I just installed an Interstate battery in my 2007 Turbo. Cost around $160. 85 month warranty and it fit exactly like the original-no modifications necessary. The vent tube outlet also lined up perfectly with the OEM vent tube. It is on the left side of the installed battery. Here are the specs:
<TABLE><TBODY><TR><TD class=product-detail-spec-title>
Product ID:
</TD><TD class=product-detail-spec-value>
MTP-94R/H7
</TD></TR><TR><TD class=product-detail-spec-title>Amps:</TD><TD class=product-detail-spec-value>955</TD></TR><TR><TD class=product-detail-spec-title>Cranking Amps:</TD><TD class=product-detail-spec-value>955</TD></TR><TR><TD class=product-detail-spec-title>Cold Cranking Amps:</TD><TD class=product-detail-spec-value>765</TD></TR><TR><TD class=product-detail-spec-title>Voltage:</TD><TD class=product-detail-spec-value>12</TD></TR><TR><TD class=product-detail-spec-title>Pro-rata Warranty:</TD><TD class=product-detail-spec-value>85</TD></TR><TR><TD class=product-detail-spec-title>Weight:</TD><TD class=product-detail-spec-value>47.4</TD></TR><TR><TD class=product-detail-spec-title>Width:</TD><TD class=product-detail-spec-value>6.89</TD></TR><TR><TD class=product-detail-spec-title>Length:</TD><TD class=product-detail-spec-value>12.4</TD></TR><TR><TD class=product-detail-spec-title>Height:</TD><TD class=product-detail-spec-value>7.48</TD></TR></TBODY></TABLE>
Product ID:
MTP-94R/H7
40 lbs?? how is it possible?? which braile you got can you tell PN??
What model #
http://www.suncoastparts.com/product...rera_T_Engineb
adnanm3
Oct 25, 2016 08:38 AM
WheelsupZR1
Oct 20, 2015 08:36 PM
