Steering wheel vibrates after changing to aftermarket wheels.....
Old Mar 4, 2012 | 10:18 AM
rlau1288's Avatar
rlau1288 is infamous around these parts
Thanks for your detailed response....i currently hv those crappy avant garde wheels on my ride...gonna change it those 3 piece forged Rotiform super concave wheels in the mid of march...should I put on stock wheels for safety?
Old Mar 4, 2012 | 10:19 AM
rlau1288's Avatar
just wondering is tht bad set up???
Old Mar 4, 2012 | 10:25 AM
rlau1288's Avatar
Actually i was running lighter wheels on mine....n it works totally perfect!!!!!!!!
Might try to put those HRE bak first!!
Old Mar 4, 2012 | 10:42 AM
vaportrail's Avatar
vaportrail is a jewel in the roughvaportrail is a jewel in the roughvaportrail is a jewel in the rough
years ago I purchased new wheels that were defective. 10 trips to the tire shop never determined the problem, and the next owner of the car found a shop to diagnose it the first time. Get a new wheel or ditch the set.
Old Mar 4, 2012 | 10:44 AM
rlau1288's Avatar
Then I guess I will put the stock wheel bak. Thanks!!!
Old Mar 4, 2012 | 10:47 AM
vaportrail's Avatar
Good idea, you don't want a defective set of wheels vibrating everything loose in an expensive car. Not worth it.
Old Mar 4, 2012 | 11:00 AM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
...the guy told me one of the front wheels are already bent...is this why?
Kidding right? Get them trued or get rid of them. Why are you running that "mess" on an expensive car? No vibration, whether lightweight or standard wheels, is normal. You're going to potentially cause other problems and it's dangerous.
Old Mar 4, 2012 | 11:42 AM
bumperpip's Avatar
bumperpip is infamous around these parts
Any good alignment shop will be able to accurately check the concentricity and/or run-out of the suspect wheel. If wheel is not very very very round, AND very very very concentric, feed it to the dealer/manufacturer at once. You did buy them new, right ?
Also, 20 inch wheels are going to be, in broad terms, more noisy, demanding, and "twitchy" than 19s. More unsprung weight, and less sidewall compliance. Good luck.
Old Mar 5, 2012 | 09:51 AM
WheelB's Avatar
Site Sponsor
WheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant futureWheelB has a brilliant future
Guys you wont realize how many wheels we see that are out of round from the box wont mention brands . And sad part manufacture tells you they are bent especially if you put it on the car they blame you instantly . this why we have best machines hunter psp9700 which does on road simulation ( and make manufacture give us new ). Find your self a hunter machine in your area and get a full road force and the machine will tell you if tire or wheel is bad ! but if that's the case only fix is a good new wheel .
Also if your retailer you bought from didn't have proper tools to measure run out its their problem not yours for not seeing this problem issue .
Also make sure your wheels are hub centric . that will also cause you a huge
nightmare .
good luck call me if you need tech advise .
now everyone know's why certain wheels cost more HRE FTW
Wheels Boutique // 786 249 0127 // Sales@wheelsboutique.com
Follow us on YouTube: www.youtube.com/user/WheelsBoutique
Largest HRE Dealer In The World / Largest ANRKY Dealer / BBS Premium Dealer / TechArt Premium Dealer / Vorsteiner / Rotiform / Akrapovic / iPE / Novitec / Brabus / AC Schnitzer / Mansory / Brembo / RENNTech / Weistec / Tubi / Hamman / KW / H&R and tons more.
Old Mar 5, 2012 | 12:23 PM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
force balance for sure.
What kind of tires are you running? While I have a hunch you are dealing with wheel issue, defective tires can also cause that...
Old Mar 5, 2012 | 06:41 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
My Cayenne came with some TechArt 22's that always seemed to vibrate at around 60-70mph. Was very annoying and I had them balanced several times to very little benefit. After I replaced the tires it all went away. Either bad tires or bad balancing.
Old Oct 13, 2012 | 10:04 AM
jeadec's Avatar
jeadec is infamous around these parts
what brand are those wheels?
Old Oct 13, 2012 | 10:16 AM
DaBrat's Avatar
DaBrat is infamous around these parts
I just realized that I hadn't given an update on the issue.
First off, my wheels were BBS.
As for the vibration, simply a case of bad wheel alignment by the shop. I had another shop align my wheels again and they have run perfectly since with no vibration at any speed.
Thank you all for your replies.
Old Oct 13, 2012 | 10:46 AM
jeadec's Avatar
That makes a lot of sense. BBS wheels are first class, they manufacture some of the OEM wheels for brands like Porsche and BMW
COBB Tuning
Jan 1, 2025 09:02 AM
MAcarbon
Mar 6, 2017 08:16 AM
no1joey
Sep 2, 2015 12:32 AM
pwdrhound
Aug 20, 2015 05:54 AM
MAcarbon
Aug 19, 2015 04:52 PM
