Do most track Accept turbo cab's?
Old Mar 11, 2012 | 06:04 PM
alexo's Avatar
alexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the rough
Looking into a turbo cab... can you track them stock?!
Old Mar 11, 2012 | 06:24 PM
DBV's Avatar
DBV
DBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud ofDBV has much to be proud of
It shouldn't be a problem for *most* tracks, as long as you keep the roof up.
Jeff C's Avatar
Jeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of lightJeff C is a glorious beacon of light
Most clubs or tracks require at least a roll bar on a cab.
GT3 Chuck's Avatar
Administrator
no..most tracks require roll over protection on any covertible..oops, Jeff beat me to it
Old Mar 11, 2012 | 06:56 PM
alexo's Avatar
Could you guys suggest a roll bar for a cab...?
Thanx alot.
BTW could I still close the roof with it?! dumb question just tried to google and havent seen one yet.
Old Mar 11, 2012 | 07:38 PM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
How about using the hardtop?
Old Mar 11, 2012 | 08:00 PM
alexo's Avatar
Because I like the soft top... !
Old Mar 11, 2012 | 08:25 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Depending on which rules you are racing with, the 911's automatic roll over protection will apply. New rules may/may not allow for this. Your 911 (post 996) already has rollover protection.
Old Mar 11, 2012 | 09:01 PM
alexo's Avatar
Sounds good thanx.
Old Mar 11, 2012 | 09:38 PM
GT3 Chuck's Avatar
Administrator
whether it is permitted or not is not the question....should it be permitted is the question...two guys were killed in a roll over at Buttonwillow in a 996 cab with the so called built in rollover protection...its your neck
Old Mar 11, 2012 | 11:01 PM
teflon_jones's Avatar
teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !teflon_jones Is a GOD !
Yes this is more the point. Highly agree. If you really want to track your car, then get a solid roof.
Old Mar 11, 2012 | 11:39 PM
Aerodude's Avatar
Aerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant futureAerodude has a brilliant future
Mixed bag here -- some events require SCCA approved roll bars, while others are OK with convertibles that have factory roll over systems. Whether you're OK with it is another matter to think about. There are other variations too -- I know of one organizer that's OK with factory protection, as long as you don't run R compound tires and are not in the advanced run groups. It's probably best to check with some of the organizers that you're considering running with.
Roll bars are not necessarily all good either. Depending on its location and configuration in your car, it can be more dangerous to have a roll bar when you're driving on the street without a helmet. There's no easy single answer that applies to all.
Old Mar 12, 2012 | 05:33 AM
Periokid's Avatar
You are not understanding. What about using the attachable Porsche hardtop? Would that work in allowing the car to run at the track? If so, a very simple solution.
Old Mar 12, 2012 | 05:46 AM
JSF721's Avatar
JSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud ofJSF721 has much to be proud of
Although I don't have all the facts, I have seen the "hard top" that goes over the cab and I do not think it offer the same structural protection of the coupe.
Old Mar 12, 2012 | 05:49 AM
Periokid's Avatar
Of course it is not the same structure as a real coupe. But does it get the car on the track? It is certainly better than the rag top over your head.
