methanol on VTGS?
Old Apr 18, 2012 | 02:11 AM
salerno713's Avatar
salerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud ofsalerno713 has much to be proud of
methanol on VTGS?
Hey Fellas, Id like to ask who is running methanol injection in their P-cars. I am trying to push the car a little more, was thinking of installing an Aquamist system along with larger injectors,and a maf-less new tune. Im running a pair of 65mm turbos for a while now and the car has always felt a little freakish on the good gas(100 Octane map), eventually going through the tiptronic transmission as well as separating the head gaskets and spinning the Camshaft after 30k miles of abuse. A couple months ago EVOMS sent my local tech their components for their 850 kit consisting of strengthening the 3.6 with new main bearings, rods, camshafts, head studs and obvious gaskets.... I love the quick spooling VTGs for the type of driving I do; but want to push a little more hp. Is meth my answer? Im thinking of having the car dyno tuned by tony @epl. Would it be possible to have the car tuned on 93pump gas, 93/ meth, 100 octane, 100 /meth? with 4 separate tunes? Is an electronic boost controller needed?
Any meth addicts care to chime in?
Old Apr 18, 2012 | 05:45 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
its great to think about meth injection , miluo is running meth on upgraded vtgs and his car running well ,, if you want a little more , yes meth is the answer !! its mean more boost , more timing !!
Old Apr 18, 2012 | 09:47 AM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
I would slap on some TiAl A30s. You'll get more hp at lower boost.
Old Apr 18, 2012 | 12:13 PM
salerno713's Avatar
I snagged a used pair of tial alpha 30s from a fellow member a couple months back; I have been hesitant to put them on as they just collect dust in my garage.. Still dont know which way I want to go with this
Old Apr 18, 2012 | 05:12 PM
yalmutawa's Avatar
yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !yalmutawa Is a GOD !
sorry for hijacking your thread
yousef can you recommend a place for me to install the aquamist in kuwait ?
Old Apr 18, 2012 | 11:18 PM
TTdude's Avatar
Blow the dust off and stick them on. You'll figure it out after that. Have you run the race file on ms109? I assume meth would be similar?
Old Apr 19, 2012 | 02:19 AM
ysfg35's Avatar
Hello yousef , well its hard to install it and tune it ! I installed 3 kits till now for porsches , one for me , 2 for other porsches am working on them !! Reema install the tank and the pump then i do the rest and the tunning !
Old Apr 19, 2012 | 08:15 AM
Emre@Esmotor's Avatar
Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !Emre@Esmotor Is a GOD !
Hello,
Meth will give you significant hp and trq increase over 93 octane pump gas.
however it FULLY depends on your tune.
Also, you cannot use an electronic boost controller with VTG turbos.
Regards,
Emre
Old Apr 19, 2012 | 12:46 PM
salerno713's Avatar
Is there a way to have multiple maps with methanol? Id like to have an option of 93 alone, 93 with meth, 100 octane alone, and 100 octane with meth.
Old Apr 19, 2012 | 03:35 PM
Slow911TT68Tip's Avatar
Slow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really niceSlow911TT68Tip is just really nice
Originally Posted by Emre@Esmotor
Hello,
Regards,
Emre
Hi Emre,
Are the % gains lower or higher when using 1 of the following 93/mix/C16 and what might those gains be? Secondly, will methanol cause any short, med, long term damage??
The only negative I can see is the tank.
I know it will reduce detonation under certain circumstances.
Thanks Much,
PG
Old Apr 19, 2012 | 11:11 PM
Fugazi's Avatar
Fugazi is infamous around these partsFugazi is infamous around these parts
I was also interested in Meth my Tuner told me that's how he blew his engine. He also said he wouldn't install it, so wen't to another guy who's also a car guru and also didn't reccomend it. I sruck out twice good luck.
Old Apr 20, 2012 | 05:37 AM
Sonny's Avatar
Sonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud ofSonny has much to be proud of
What tuner? For shure he did not know what he was doing.
Old Apr 20, 2012 | 07:56 AM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
salerno.....there's a customer of ours up in the NY/CT area running our 68mm VTG's, and added meth to the kit. Talk to Tony @ EPL...he knows the car. It belongs to arone997tt, but I'm not sure he posts on here too much anymore.
Basically, he uses the meth when in both the pump and race fuel modes of the GIAC programs. He's not specifically programmed for it, but it helps for sure. If you did a custom tune for it, I'd bet the benefits would be even better.
Old Apr 20, 2012 | 10:41 AM
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
I run straight methanol for 3 years now on VTGs there are a few topics on the forum. EPL is a good option
Old Apr 20, 2012 | 12:45 PM
Arone997tt's Avatar
Arone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud ofArone997tt has much to be proud of
Tom, how's it going? im still here!!! just not as much as would like to b
