New Leds from Maxspeed installed
Old May 15, 2012 | 02:06 PM
  #31
Nello@Maxspeed's Avatar
Nello@Maxspeed is a jewel in the roughNello@Maxspeed is a jewel in the roughNello@Maxspeed is a jewel in the rough
Originally Posted by wasserson
I just installed my lights last evening. They are a fantastic big bang for the buck upgrade! I found that if the polarity on the left rear license plate light is backwards, it causes both lights to fail. When I switched the left rear to it's proper direction, voila, both lights went on. I am having trouble figuring out how to get to the bulbs in the footwell lights. My car is going to the dealer tomorrow for routine maintenance and I am going to have them install the footwell bulbs. It would be helpful to have instructions on how to open the footwell casings once removed from the car.
Hello, it's fairly simply to replace the foot well bulbs, you need to pop out the lens with a screwdriver you will see a spot on the lens where you can insert a screwdriver or similar tool between the lens and surface, you will then see a metal heat shield that covers the bulb, simply spread the metal sheet open by spreading it on each side and remove, this will give you access to the bulb, to install the new led bulb do the reverse of course once you put that metal heat shield back on the lens simply squeeze it to give it its original shape back . Thanks
Old May 17, 2012 | 05:06 PM
  #32
johngoga's Avatar
johngoga is infamous around these parts
Originally Posted by Nello@Maxspeed
Hello you won't be disappointed, please post your comments here once you've installed them.
Best,
Nello
Nello,
Question for ya, i ordered a set on the 10th today is the 17th any idea where my set is?
John
Old May 17, 2012 | 08:08 PM
  #33
Originally Posted by johngoga
Nello,
John
Hello I just replied to the e-mail you sent me. Please check your e-mail. Your order has been shipped. Please confirm receipt of the e-mail I sent you today on 5-17-12 Thanks
Old May 25, 2012 | 08:39 PM
  #34
5hlinmd's Avatar
5hlinmd is a jewel in the rough5hlinmd is a jewel in the rough5hlinmd is a jewel in the rough
Great upgrade. Mine were shipped fast. Installation was painful but straight forward. The only suggestion is better directions for the dome light install. I got it done, but I think I pried off just the lens when I should've taken the whole assembly out. Broke a few of the tabs on the lens so it doesn't sit flush. Oh well. Otherwise, LOVE the new look inside and out. Thanks Nello!
Old May 26, 2012 | 05:09 PM
  #35
1pennyshort's Avatar
1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about1pennyshort has a spectacular aura about
+1 on this upgrade, totally worth it.
Installation was easy. The user manual has directions for almost everything. I think the only spots I could not find were the footwell and glove box lights; that's where the instructions from maxspeed helped.
Do one light at a time and check polarity before moving to the next one. Should take less than half hour.
COBB Tuning
Jan 1, 2025 09:02 AM
Michael_s
Sep 11, 2015 08:03 PM
tkebp1275
Aug 31, 2015 06:35 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
ppwchiang
Aug 20, 2015 10:28 AM
