Low boost pressure
Old Jun 27, 2012 | 09:39 PM
nflpats's Avatar
nflpats is infamous around these parts
Low boost pressure
2011 Porsche 997 Turbo
Today I was getting driving my car and the boost would not go past 2psi. I pulled over and turned off the engine for 5 minutes. When I got on the car again, this time the boost hit 15psi. Last week I installed a catless valvetronic exhaust feeding off a vacuum line to actuate the valve. The vacuum closes the valves and when the car goes over 3500rpm the valves open (no longer needing vacuum). I never had a problem before until today. The temperature today was 107 degrees, not sure if that played a part.
Here is the pic of the vacuum tube I used to feed the valvetronic. It is the clear tube with a small black connector. I believe it goes to the throttle body? I used a T fitting to feed off of. The clear tube is located next to the rear axle and transmission. Here is a photo.
Anyone might have a suggestion as to what might have been the problem? The car seems to be running fine. Also, before the exhaust the max was 11psi, now its 15psi.
Old Jun 27, 2012 | 11:15 PM
TT_Crab's Avatar
TT_Crab has a spectacular aura aboutTT_Crab has a spectacular aura about
Did you get a CEL?????
Old Jun 28, 2012 | 12:10 AM
nflpats's Avatar
I did not get a cel when this happened; however, I got a cel just tonight just after I wrote this thread. I will have to find the code but I cant imagine it being the O2 sensors because I bought the mini cat 02 plugs from bigdaddiesgarage.
Old Jun 28, 2012 | 12:23 AM
TT_Crab's Avatar
If the car misfires at idle then you have a vacuum leak. Did you check the hoses in your intake at all? Also you MAF sensors? Maybe something's loose there. It can even be a Y-pipe clamp that came off or even an intercooler hose that got loose...
Old Jun 28, 2012 | 12:51 PM
nflpats's Avatar
The cel code I got was P2099 (rear O2 sensor). I bought the bigdaddiesgarage mini cat sensor and they didn't work.
Old Jul 13, 2012 | 11:58 AM
Kafka997's Avatar
Kafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond reputeKafka997 has a reputation beyond repute
Yes
From my experiences with loss of boost these are good ideas. I did have a CEL with my MAF issue. Hopefully it will just be loose hose - it happens. Unlikely it's any thing serious.
Hope you get it resolved asap.
K
Rguy
Apr 12, 2020 11:11 PM
Jul 29, 2019 11:13 AM
HotRod
Sep 10, 2015 07:17 PM
