Another 997 Turbo Maxspeed LED Upgrade
Old Jul 31, 2012 | 10:34 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Originally Posted by mikestyle
What are you talking about????
Inside of the led cluster is a lens that covers the bulb. What I am saying is I pushed one off when putting the new bulb in because it was too long. Take a look at your car!
Old Aug 2, 2012 | 09:40 PM
mikestyle's Avatar
mikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud ofmikestyle has much to be proud of
Ok Ok interesting, good thing to watch out for. I never had any problems. As long as this is known and you are careful im sure it shoudent be a problem.
Old Aug 3, 2012 | 12:38 PM
C4TT's Avatar
C4TT is infamous around these parts
Sweet, just ordered mine!
Thanks,
G
Old Aug 3, 2012 | 01:12 PM
eurotom's Avatar
added another pic with headlights on.
Old Aug 3, 2012 | 03:21 PM
C4TT's Avatar
So what did you do about the bulb being too long?
Old Aug 6, 2012 | 01:24 PM
eurotom's Avatar
I took an orbital sander to the bulb and ground it down a bit. The contacts are long enough to allow for this. I've attached a few photos to illustrate my issue please note this is is only specific to the front city lights and no other bulbs. Also I'm not suggesting this is a Maxspeed specific issue I just want people to be aware.
Ive attached 3 photos:
1. Drivers side with no mods done to the bulb, note the vertical red line which shows the edge of the lens within the housing. Note how close the bulb is to the line.
2. Modifiied bulb on the passenger side note the gap
3. Side by side of "OEM" vs my griding action
Old Aug 6, 2012 | 01:34 PM
Carlitos way's Avatar
Carlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really niceCarlitos way is just really nice
I guess you had received the wrong city light bulbs because I did not had to shave or modify anything, everything fitted perfectly.
Old Aug 6, 2012 | 01:39 PM
eurotom's Avatar
It's really difficult to say we're talking about 1/32 to 1/16" between a perfect fit and popping off a lens. There is variance in the tolerence of the bulbs, my light strip, the lense within the light, and of course lets not forget the operator I didin't want to take a chance again so I modified it. I had no problem with the drivers side.
Old Aug 6, 2012 | 03:00 PM
C4TT's Avatar
Awesome! Thanks for sharing the photos. My bulbs arrived today so I'll take a stab at the front lights tonight!
Old Aug 6, 2012 | 03:18 PM
eurotom's Avatar
Cool post pics when you're done and don't knock of a lens otherwise you better be very good at building ships in bottles
Old Aug 7, 2012 | 08:33 AM
C4TT's Avatar
OK so I did the front lights, clear corners and license plates for now. I'm probably going to hold off on interior since you felt it was dim.
What I noticed as I was attempting to reinstall the front running light bulb fixture into the housing was that the LED bulb itself was pivoting between the connection blades because of the tight space, therefor when I started to lock the fixture while turning, it started to push on the thin leg of that notorious lens! I halted, back out, straightened the LED and went at it again and prevailed!
Great inexpensive mod. I will post photos this evening.
Thanks for posting Euro!
G
Old Aug 7, 2012 | 09:31 AM
eurotom's Avatar
Hey G happy to hear it worked out for you without a hiccup. I'm glad I could help. Regarding your dim comment. I mentioned earlier that only the engine compartment bulb was dim all the other interior lights including the frunk worked perfectly. Not sure why since the bulb for the frunk/engine and center dome are the same but maxspeed is aware of it and hopefully they'll have a solution. Enjoy!
Old Aug 7, 2012 | 09:49 AM
C4TT's Avatar
Gotcha, wife called me in for dinner, so I called it at night
I'll look at it later.
Thanks,
G
Old Aug 8, 2012 | 10:01 AM
C4TT's Avatar
Here are a few pics after the clear bra was installed last night. Well worth it if you ask me.
Old Aug 8, 2012 | 10:27 AM
eurotom's Avatar
Nice now get those side marker bulbs in. So what do you think about how well it matches with the headlights? In my opinion an upgrade to 6k headlamps would match better.
