Changing wheels with PCCB's
Old Jul 31, 2012 | 05:11 PM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
Needing to install the spacer, I was bit concerned for an accidental slip and causing damage to rotors/calipers.
While sitting in the garage and thinking a way to lower the risk, I found some bubble sheet wraps laying around so I went to work.
Make sure you jack up the car as high as possible so as to get a better grip on the wheel/tire especially the rear ones.
Once you get the wheel on the mounting poles,just pull the wrap off and slide the wheels on...
So what do you all think about my creativity
Old Jul 31, 2012 | 06:12 PM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Haha nice one did you bubble wrap the entire car?
Old Jul 31, 2012 | 08:04 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
I use to put a towel around the caliper and rotor ( it was tight fit) then I would use two guide pins with them positioned at 9 & 3. I was more concerned about scratching my rims! : )
Ceramic's are over rated...steel is real.
COBB Tuning
Jan 1, 2025 09:02 AM
turbotuner20v
Sep 11, 2015 12:02 PM
00aston
Aug 27, 2015 12:01 AM
ModBargains
Aug 20, 2015 12:28 PM
turbosonoma
Aug 19, 2015 02:05 PM
