Tire Pressure Sensors Replaced
Old Aug 17, 2012 | 07:58 PM
997TTurbo's Avatar
997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold997TTurbo is a splendid one to behold
Learned through the forum that the battery life on the tire pressure sensors is around 5 years. When the battery on any of the sensors weakens, it throws the dreadful "TPS Inactive" code on the on-board computer. Even if you reset it, the system will not "learn" and you will continue to have the red exclamation point and the amber tire pressure warning light on the dashboard.
I took my 2007 Turbo to Wheel Enhancement in Los Angeles and they replaced all 4 sensors with new sensors, Porsche part# 997.606.021.01. They carefully removed the tires, broke the bead and reached in and removed the old sensors and installed the new ones.
Wheel Enhancement is awesome, they made sure that there would be no scratches on the rims and their work was flawless! I dealt with Dave Martin. Not a cheap fix ($600) but well worth it to me since I like to have everything working correctly. After I drove off from their driveway, the computer reset itself and the warning lights went off and I was back in business with the TPMS working perfectly. Wheel Enhancement is a forum sponsor and I give them the thumbs up
Old Aug 18, 2012 | 02:31 PM
Porsche997TT's Avatar
Porsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to beholdPorsche997TT is a splendid one to behold
I was quoted $950.
What was the cost for parts only?
Old Aug 18, 2012 | 06:13 PM
jhbrennan's Avatar
Originally Posted by Porsche997TT
I was quoted $950.
http://www.suncoastparts.com/product//TPMSensor.html
Old Aug 18, 2012 | 11:30 PM
997TTurbo's Avatar
Wheel Enhancement charged $135 per sensor so 4 of them were $540 plus $60 to install them. They ship also. You can get the sensors from them or other forum sponsors/vendors and then pay a good tire place to install them. Heard the dealer charges $950-$1000! Save yourself some money and get the parts yourself for an easy fix to the TPMS problem.
Old Aug 27, 2012 | 01:38 PM
ShopTPMS's Avatar
ShopTPMS is infamous around these parts
We also carry them 2007 997TT $419 per set with the required valve stems:
Old Aug 29, 2012 | 11:51 AM
bostonjd's Avatar
bostonjd is infamous around these parts
I know which sensors to get (RDE010) but how do you know which stems to get?? Tirerack asked me to send them a close-up picture of the valve stem and from that they told me I should get RDV003 but I have no idea how they are telling that from the picture. I have 2012 Panamera Turbo if that matters specifically... Sensors are $102 each and stems are $8 each...
Old Aug 29, 2012 | 12:04 PM
MJA's Avatar
MJA
MJA is just really niceMJA is just really niceMJA is just really niceMJA is just really niceMJA is just really nice
2012 Panamera, Are your sensors bad or getting aftermarket wheels. They should be covered under your warranty if they are bad...
Old Aug 29, 2012 | 12:23 PM
bostonjd's Avatar
Got separate 19" turbo wheels (oem, dealer take off but without TPMS) for winter....
Old Aug 29, 2012 | 12:37 PM
jhbrennan's Avatar
I believe you can supply your VIN to Suncoast and you'll be sure to get the correct ones. I'm sure all Porsche dealers can do this, not sure about other vendors though.
Old Aug 29, 2012 | 03:56 PM
ShopTPMS's Avatar
The RDV003 has a larger base but same length valve as the RDV001. We have found the RDV001 has worked on 99% of the Porsche vehicles we have done
RDV003
RDV001
and yes the 2012 Panamera uses the RDE010 433MHz
Jul 29, 2019 11:13 AM
PenguiN
Sep 15, 2015 11:44 AM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
Aug 19, 2015 06:35 PM
