TSB Question
Old Aug 26, 2012 | 10:22 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
TSB Question
Hi All,
Quick question regarding the following TSB which seems to cover most 2007-2009 turbos: "W902 - Reworking Adjustment Mechanism for Variable Turbine Geometry (VTG)"
The TSB shows the following 2007 VINs are affected
USA 2007 911 Turbo/GT2 (997)
WP0AD29927S783102 to WP0AD29967S786908
My Question is if my VIN is WP0AD29997S7868XX do I fall in this range? Are the last 6 digits all that matter? if so I guess I fall in the band
In any case if I call a Porsche dealer with my VIN and the associated TSB can they check to see if the previous owner completed the service?
thanks
Old Aug 27, 2012 | 06:37 AM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
You can call your dealer with your VIN # and they should be able to tell you all the recalls/bulletins/etc. for your car and which ones have or have not been done.
Old Aug 27, 2012 | 06:55 AM
jhbrennan's Avatar
Originally Posted by aa909
Hi All,
thanks
Last 6 are the important ones. And as already mentioned, dealer can check your VIN to see if bulletin was taken care of.
http://www.autohausaz.com/porsche-au...n-numbers.html
Old Aug 27, 2012 | 08:21 AM
aa909's Avatar
Thanks guys, I just had the car inspected thoroughly during a PPI this past Wednesday and all was reported to be in good working order. I even asked the lady at the service desk to run a VIN check for any open recalls and it was clean. Is there a difference between "recalls" and "TSBs"?
I'll double check with them this morning to confirm. BTW what would be a symptom if one of these turbo actuator rods were sticking?
thanks
Art
Old Aug 27, 2012 | 10:38 AM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
A recall is a repair that the dealer will fix free of charge. Most often a safety hazard.
A TSB is a technical service bulitin. This is used as a technician note. If they are searching for a problem, and there are common reports of the same issus, they will issue a TSB. It aids in diagnostics. A TSB is not a recall. It will not be done unless needed, and is not done for free, unless it is a warranty repair.
Mike
Old Aug 27, 2012 | 10:40 AM
aa909's Avatar
Mike
thanks for clarifying Mike. So when I asked the service desk to check for any open recalls under my VIN would the outstanding TSBs also have shown up or would this be a separate check?
Old Aug 27, 2012 | 10:56 AM
aa909's Avatar
dealer just confirmed W902 was completed per VIN check back in 2009
this board rocks, thanks all!
Art
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
