"Sticky" gearshift 997 Turbo MK1
Old Aug 27, 2012 | 07:37 AM
Viv's Avatar
Viv
Viv is infamous around these parts
Hi guys, I'm brand new to this forum, just want to know from other 997 Turbo MK1 (manual) owners if they are experiencing the same "problem" as I have. Recently upgraded from a 996 Turbo to a 997 Turbo mk1, I find changing from 1st- 2nd very "sticky", meaning the shifter doesn't just glide in, but I need to use more force than with any of the other gearchanges. Is this normal? My 996 all gearchanges were very easy, now with the 997 it is very tricky especially when wanting to pull off fast and accellerate.
Old Aug 27, 2012 | 07:59 AM
mm450exc's Avatar
mm450exc is infamous around these parts
This is normal. Especially with the short shift.
Old Aug 27, 2012 | 08:48 AM
Viv's Avatar
Viv
Red face
"Short shift" meaning the standard gearlever? What is the best way to change, just force a quick change? Maybe I must just get used to it.... just bought the car 2 weeks ago
Old Aug 27, 2012 | 08:56 AM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Yup, that's normal... essentially you're replacing less throw/distance (due to a shorter leaver) with more force. Physics 101
DaveH's Avatar
DaveH is a jewel in the roughDaveH is a jewel in the roughDaveH is a jewel in the rough
Short shift is an option. Just makes the throws shorter. I don't have any issue with engagement. I too had a 996TT previously, and other than longer gear throws with its standard box, from what I remember, the 997 doesn't feel any more awkward. If anything, it's smoother and more direct. Now if you want a tractor-like gear shift, a C6 Vette owns "sticky".
Old Aug 27, 2012 | 08:59 AM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
my 07 feels the same. I wouldn't call it "sticky", more like a stiff 1st to 2nd shift but as you noted the shifts to 3rd and beyond are very smooth. I drove 6 different 07-08 manual turbos before purchasing and all were exactly the same in terms of the 1st to 2nd shift being stiff
hope that helps
Art
Old Aug 27, 2012 | 09:11 AM
Viv's Avatar
Viv
hope that helps
Art
Agreed, maybe "stiff" is a better word to use, I just find it strange as my 996 did not have this, any thoughts on putting a different gearbox oil in? Could that not help with the "stiffness"?
Old Aug 27, 2012 | 09:39 AM
swole305's Avatar
swole305 has a spectacular aura aboutswole305 has a spectacular aura aboutswole305 has a spectacular aura about
Agree my car is the same - 08 TT - but after it warms a little it's not a noticeable.
Old Aug 29, 2012 | 03:51 AM
Viv's Avatar
Viv
I actually took the car out yesterday and drove it hard for about an hour and think I am getting used to the gearshifts. It seems you have to really force the shifts and by doing that you can achieve fast shifts, but 1-2 will take a bit of getting used to, I am actually going down to the dealership this afternoon and will ask to drive another TT just to feel if it is the same! Regards
Old May 10, 2013 | 09:03 AM
M9L's Avatar
M9L
M9L is infamous around these parts
Same issue 07 TT, also switching 2nd to 1st unless at a complete stop is tricky.
Old May 10, 2013 | 09:07 AM
jhbrennan's Avatar
08 with SSK option - all shifts smooth except into 1st when cold. You ought to check out adjustment - shouldn't be "sticky".
Old May 10, 2013 | 09:15 AM
M9L's Avatar
M9L
Thanks, can you elaborate what you mean by adjustment?
Old May 10, 2013 | 10:06 AM
UTPorsche's Avatar
UTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond reputeUTPorsche has a reputation beyond repute
I'm with M9L - going from 2nd into 1st feels stiff to me, but going from 1st to 2nd doesn't take any extra force. I think going by the dealer is a good idea- I've driven other 997's to see if mine was "normal." (it mostly is )As long as you don't hear any grinding and the gears engage correctly I wouldn't worry too much about it (even if it's not "normal").
Old May 10, 2013 | 10:16 AM
M9L's Avatar
M9L
Thanks for the opinion. Had the car with 5K on the clock now 14K been like that since day one no grinding just some stiffness. No major issues on the track or daily driving just annoying in traffic. Figured if it is smth bad it would deteriorate to smth more obvious then I would take it to dealer.
Mackchacha
Jul 9, 2019 11:03 AM
PelicanParts.com
997 Turbo Vendor Classifieds
Aug 20, 2015 02:38 PM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
PelicanParts.com
Aug 18, 2015 03:41 PM
