Modified 997.1 tt tech question
Old Sep 19, 2012 | 09:27 PM
cfpchfc1's Avatar
cfpchfc1 is infamous around these parts
Hello everyone
Is it possible/likely for a fullyengine upgraded car (short of engine rebuild, but everything else, with 65mm vtg's, etc) to produce greater hp/tq by just going from a 82mm plenum to a 74mm?
What am i missing?
Old Sep 19, 2012 | 11:27 PM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
74mm TB ( stock 997tt TB ) is fine for 1100-1200whp engine setup
Old Sep 20, 2012 | 08:35 PM
cfpchfc1's Avatar
Really???
Old Sep 20, 2012 | 09:33 PM
512bb's Avatar
512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of512bb has much to be proud of
Yup! To make power you need to get in more air, which is a simple concept, however, air acts very funny at high speeds and the path for the air has to be designed and tuned very specifically for certain flow rates. Because of that, in certain situations the tune is better with a smaller diameter where you get the accelerate the air (the velocity stack concept).
To that end, take a look at the stock air filter housing, which is designed to work as an accelerator and a velocity stack working in conjunction with the throttle body. The stock airbox is designed for about 1,000 hp.
Cheers.
Old Sep 21, 2012 | 03:28 AM
jtchui's Avatar
jtchui is infamous around these partsjtchui is infamous around these parts
I was considering going from 74mm to 82mm haha. You are doing the opposite?!?!?
Old Sep 21, 2012 | 04:41 AM
Originally Posted by cfpchfc1
Really???
Yep. Both stock plenum and TB should be fine.
Stay away from 82mm TB..No real gain
What is your current mods?
Old Sep 21, 2012 | 05:45 AM
cfpchfc1's Avatar
Well, i just went from 82mm to 74mm and FEEL a very significant gain, I'd say 50ft, 30hp if not greater!
My configuration is fully upgraded including 65mm vtg's, airbox is stock and internals unchanged.
I could not believe what I was experiencing.
Thank you all.
I learn something new everyday!
COBB Tuning
Jan 1, 2025 09:02 AM
docboy
Sep 6, 2015 06:57 AM
Sales@RSW
Sep 3, 2015 09:34 AM
991carreradriver
Aug 30, 2015 04:16 PM
The Oss
Aug 24, 2015 08:19 PM
