Mechanical difference between 997.2 TT and TTS
Old Nov 6, 2012 | 10:43 AM
RollingThunder's Avatar
RollingThunder is infamous around these parts
In the market and trying to decide whether to hold out for the right S or take a non S PDK with sports chrono which I like. From what I understand, a tune will bring the non S to the same power level as a S. If software can achieve this, my question is whether there is any difference mechanically in the engine or transmission in the S, or are the parts the same so the S is not any more durable mechanically than a non S? Thanks.
Old Nov 6, 2012 | 01:51 PM
TT_Crab's Avatar
TT_Crab has a spectacular aura aboutTT_Crab has a spectacular aura about
No mechanical difference at all... the engine is exactly the same.
Old Nov 6, 2012 | 02:02 PM
svoshop's Avatar
svoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond reputesvoshop has a reputation beyond repute
I may be wrong, but I thought the S had different turbos...
Mike
Old Nov 6, 2012 | 02:23 PM
TT_Crab's Avatar
Part nr's 9A1-123-013-74 for left turbocharger and 9A1-123-014-73 for the right one on both models. It's just a flash that makes the difference.
Old Nov 6, 2012 | 07:51 PM
DÜnkleblau S's Avatar
DÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant futureDÜnkleblau S has a brilliant future
...dont forget the carbon fiber air box
Old Nov 6, 2012 | 08:18 PM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
Is the entire drivetrain, suspension and exhaust setup the same as well? if so then what are the differences to justify the premium when anyone can buy a software flash and have a Turbo which will out perform a stock Turbo S?
Old Nov 6, 2012 | 11:33 PM
TT Chris's Avatar
TT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud ofTT Chris has much to be proud of
It's all the same. Turbo S comes with more standard features that are optional on the turbo. If you optioned out a turbo to what a turbo S has the turbo S is cheaper and has a bit more power too. So value wise the turbo S is better if you want everything that comes with it.
Old Nov 7, 2012 | 07:42 AM
P-car Fan's Avatar
P-car Fan is infamous around these parts
Also, with the turbo S you get the extra power w/ a full Porsche warranty, not true if you get a turbo and then tune it. Personally, I feel the two are so close to being equal that you should just get the regular turbo
Old Nov 7, 2012 | 07:56 AM
JmanE55's Avatar
JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !JmanE55 Is a GOD !
Also, the PCCB come standard on the TTS.
Old Nov 7, 2012 | 07:59 AM
TAILWAG's Avatar
TAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond reputeTAILWAG has a reputation beyond repute
amazing what a little marketing can do, huh?
Old Nov 7, 2012 | 08:06 AM
Thanks for all the info. I understand the warranty issue wih the tune and that a S may be more economical in some instances because of the standard items like ceramic brakes. My concern was more about whether there was some mechanical/physical difference in the engine or powertrain that is not even offered as an option for a regular turbo. Other than the carbon fiber air box, it appears the answer is "no."
Old Nov 7, 2012 | 02:20 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
So if you tuned a TT the power should be the same as TTS? What happens if you tune a TTS? Will the TTS now be faster than a tuned TT or the same?
I'm in the same dilemma you are. Have a TT and TTS I can buy and the difference is about $20K....
Old Nov 7, 2012 | 02:22 PM
I am not an expert, but from what I have read, the tuned turbo an tuned turbo s would have the same power levels. That is why I wanted to know if the internals are the same for longevity purposes.
Old Nov 7, 2012 | 02:26 PM
C4SxM5's Avatar
any tuners can chime in?
would a tuned TT be the same as a tuned TTS?
Old Nov 8, 2012 | 12:01 AM
Zero911's Avatar
Zero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to allZero911 is a name known to all
If the car's are both physically the same cept some options are included at a reduced price as part of the package and it's a software difference, then tuned TT and tuned TTS should be the same. If you were able to tune the TTS to be better than a stock TTS, then I don't see why you wouldn't then flash the TT to have that same better tune resulting in again both being the same.
