Sponsored by: Bears Transport
DCTMS 997.2 extra thick steering wheel installed on a 997TT
Old 01-30-2013, 02:26 AM
DCTMOTORSPORTS's Avatar
DCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond reputeDCTMOTORSPORTS has a reputation beyond repute
Another project finished for 997.2 type steering wheel
This is a steering wheel for Panamera customer
but similar type for 997.2 steering wheel
Old 05-16-2013, 10:22 PM
Another 997.2 carbon steering wheel
Here is another carbon sport steering wheel for 997.2 with
- extended carbon bottom
- sportive molding
- custom ring on top
- custom stitching
Old 05-16-2013, 11:26 PM
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Originally Posted by DCTMOTORSPORTS
YES!
We made more than 100pcs 997.1 steering wheel conversions already
997.1 wheels are generic, you can swap your multifunction tabs or tiptronics tabs from original wheel to the new wheel. There are 2 types of 997.1 wheel
standard type with triangle airbag
sport type with circle airbag
You can also check this thread for more projects we made
997.1 wheels
Hi
How much and what do I need to install the 997.2 steering wheel (multifunctions with PDK) for my car (2007 tiptronic Turbo)
Old 05-17-2013, 09:39 AM
eurotom's Avatar
eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !eurotom Is a GOD !
Originally Posted by Leo997TT
Hi
Leo DCTMS does not do retrofits, they will simply take your wheel and replace it with a modfied version.
You need to source the required parts and core PDK compatible wheel from Suncoast.
You Have two options:
Option 1
PDK wheel with paddles(no multifunction ) $989.
Airbag - $946
Steering wheel control module ~$220
Dealer programming and install ????
Option 2
Standard PDK wheel Push button type - ~$800
Airbag - same as above
Steering wheel control module- same as above
Multifunction switch kit for PDK - $650.
Dealer programming ????
Note in option two I've listed the MF switch kit seperately as when I requested to order a wheel with the MF already on there it was about 1k more than buying a standard wheel and replacing it with a multifunction face.
Once you have this sorted out you can send your wheel to DCTMS which will likley costs you 1k depending on configuration. Additional note: The wheel you just purchased is not the wheel that will be modified unless you request so. DCT and other companies have an inventory of cores that they use as base for you configuration, that is why you send your wheel in after the fact.
Pricey yes but a good mod, especially for tip guys.
Old 05-17-2013, 02:36 PM
Option 1
Airbag - $946
Option 2
Very detail and helpful information, and once you guys finished the upgrade, consider sell the original wheel to us, we always need the cores.
Old 05-17-2013, 02:45 PM
jgood's Avatar
jgood will become famous soon enough
What about adding paddle shifters from a .2 to a .1 tiptronic wheel?
Old 05-17-2013, 09:57 PM
eurotom's Avatar
Yes reference Option 1 listed above in this thread: If you decide to move forward contact Ric and Suncoast he will ensure you get the correct PN's on order.
https://www.6speedonline.com/forums/...nic-turbo.html
Old 05-18-2013, 07:16 AM
jgood's Avatar
I want to keep the multi function part of my wheel and add paddle shifters.
Old 04-23-2014, 10:29 PM
pureporsche's Avatar
pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !pureporsche Is a GOD !
Hi DCM, I'm looking for exactly the same multifunction 997.2 steering wheel as above, minus the paddles (behind the wheel) and the shifter buttons for my 997.1.
Could you provide cost with airbag?
Also what would the exchange be for an OEM core with airbag (multifunction 997.1 "triangle" wheel, black leather).
...I would assume I'd just need the control module from suncoast to make this all work.
Old 04-24-2014, 03:25 PM
cannga's Avatar
Hi Ivan,
Beautiful work and I don't think I could resist. Questions please.
The sand beige wheel below has a thumb "defect" at 3 and 9 o'clock positions that I don't necessarily like (I am not talking about the thumb rest, but the concave defect/notch BELOW the thumb rest).
The extra thick black wheel does not **seem** to have this defect.
1. If I don't like to have that defect, do I have to order the extra thick wheel?
2. Are you familiar with BMW e90 M3 stock wheel? It has perfect thickness for me. Which one of your two wheels are closest to thickness of M3?
3. Would you please PM me some of the shops that have done the most wheels for you in Southern Cal?
NORMAL Thickness Wheel with "defect."
EXTRA Thick Wheel with seemingly less defect.
ID:	365443   Click image for larger version
Old 05-07-2014, 10:27 PM
BUMP... DCM please see my note above. Looking to get this wheel in my car
Old 05-23-2014, 08:56 PM
All alcantara type 997.1 987.2 thick padding steering wheel
Here is another project we made for customer
Name:	14113 997.2 thick Alcantara wrap (1).JPG
Old 05-29-2014, 05:18 PM
pvanosta's Avatar
pvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nice
subscribing
Old 08-01-2014, 10:53 PM
Porsche 997.2 991 Porsche Sport Design steering wheel DCTMS conversion
Finish another new Porsche Sport Design steering wheel with
- DCTMS sportive flat bottom design
- GT3 9052 alcantara wrap
- Color ring on top and color stitching
Old 08-02-2014, 07:22 AM
Squat's Avatar
Squat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to beholdSquat is a splendid one to behold
LOL thats not a defect, its for ergonomics....
Quick Reply: DCTMS 997.2 extra thick steering wheel installed on a 997TT
