Upgraded VTG opinion please
Old Jan 19, 2013 | 11:02 AM
  #31
The Bogg's Avatar
Originally Posted by GTRNICK
I wonder if the CMS 68mm will connect to the Evoms intake hoses as they are far cheaper than the CMS carbon intake hoses?
I think so. I had looked at this option too - trying to save $$, lol. There's also a dyno print on this forum where someone used the stock air inlet pipes with 68s. I haven't seen data to show that there is a difference between stock and aftermarket pipes as far as flow, or where the bottleneck occurs, or at what power level it matters but if Champion says the 68 works best with the upgraded inlet pipes then I guess it makes sense to get them if you're trying to get the max out of the turbos. No shortage of snake oil out there but I don't think Champion is like that based on their heritage, board presence, etc....
Old Jan 19, 2013 | 11:05 AM
  #32
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Originally Posted by yumaverick
With VTG's you can make 650whp, which is a lot more than 700crank. I believe the problem is that you don't get consistent runs at that power level because the turbos get so hot so it will back down a little. With the bigger turbos you can run it all day with out losing power.
Right with the idea of no loosing power because heat with big turbos.
But I believe 650whp with vtgs is not possible with pumpgas, all the engines I met, from Rstuning, Sportec, Switzer and Protomotive couldn't exceed 700-750. Crank hp...
Old Jan 19, 2013 | 11:17 AM
  #33
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Yes I agree with K24F, there is no way you will get more than a safe 700crank out of VTG's. the over inflated figures are usually from dyno's that have not been setup properly by the operator IMO!!!!
Old Jan 19, 2013 | 12:06 PM
  #34
The Bogg's Avatar
At the end of the day the dyno numbers don't really matter as much as the 100-200km/hr or 60-130mph results...
From what I've seen there are manufacturers that quote anywhere from 650-750hp with upgraded vtg packages but the times for 60-130 seem to be very close to each other...
Old Jan 19, 2013 | 12:20 PM
  #35
xbox_fan's Avatar
xbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond reputexbox_fan has a reputation beyond repute
I am curious to the differences between vendors VTG upgrades, vividracing doesnt provide any real details on theirs (compared to CMS in this thread at least) but they are almost half price compared to CMS...
Old Jan 19, 2013 | 12:41 PM
  #36
GTRNICK's Avatar
Again I agree with the performance times testing it's the only way!
  #37
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
CMS VTG's are expensive because they use billet housings. It's necessary for the 68 VTG's but not for the 65 VTG's.
Other vendors use factory housings on the 65 VTG's and some also extrude honed turbine housings.
FVD VTG's are 66mm
And then there's the small and cheap 63,5 VTG's
Old Jan 19, 2013 | 12:42 PM
  #38
GTRNICK's Avatar
Maybe their compressor blades are made from cut back coca cola cans that's why!? (Joke)
Old Jan 19, 2013 | 12:45 PM
  #39
The Bogg's Avatar
I had asked Proto about upgrading to 65vtgs from 63.5vtgs and was told that on pump gas the 65s they had would introduce more lag with minimal gain. If racegas, E85, or methanol was used it was worthwhile. Check with whatever manufacturer you use about their recommendations b/c Proto could easily have just sold me the 65s - like shooting fish in a barrel!
Old Jan 19, 2013 | 12:49 PM
  #40
w00zy's Avatar
Have you asked about the extrude honed turbine housings?
Todd told me it has dramatic improvement in low speed boost response and much better ignition timing numbers
Old Jan 19, 2013 | 02:10 PM
  #41
GTRNICK's Avatar
Can explain what you mean please?
Old Jan 19, 2013 | 02:49 PM
  #42
twturbo's Avatar
twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !twturbo Is a GOD !
I have the vivid turbos & like someone just said you can't get an answer out of them as to what there specs are ,I'm guessing 63.5 but does anyone know for sure ? I will be upgrading in the near future ,my tuner wants me to go gt's as I already have side air inlet pipes.
Old Jan 19, 2013 | 03:14 PM
  #43
The Bogg's Avatar
Any vbox numbers with the current ones?
Old Jan 19, 2013 | 03:17 PM
  #44
The Bogg's Avatar
If Champions 68vtg didn't exist I'd consider extruding the 63.5. Ignition timing numbers are better, which translates to more power higher up. I recall that it was good for about 0.5s drop in 100-200 time for some users.
Old Jan 19, 2013 | 03:55 PM
  #45
K24F's Avatar
A kind of polishing the inside and exit of the housing to improve the flow.
