Upgraded VTG opinion please
Old Jan 22, 2013 | 07:30 PM
  #121
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Tom-thx for the reply. How has durability been on 68mm VTGs been?Your thoughts there?
What fuel is being used?( specifically on high HP applications)
Old Jan 23, 2013 | 05:37 AM
  #122
DARTH-VADER's Avatar
DARTH-VADER is infamous around these parts
Originally Posted by milou
Hmmmm, it would be great to compare to tips with 700hp package from different tuners, i can provide any 0-100, 60-130, 100-200 , 200-300 300-400;-) 1/4mile full mile, etc for comparison, i run pump fuel and meth so its almost like running on racefuel. I can also list my modds which i think are less than yours ;-)
My mod list is even less than yours.I think you have modified exhaust housing on 63.5mm vtg's.I use stock housing with 63.5mm.I run pump gas(91 octane) plus methanol.NO aftermarket intercoolers.
100-200 5.3secs
60-130 6.3secs
Old Jan 25, 2013 | 02:39 PM
  #123
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Hi Red...
The oldest set of 68mm VTG's I have out on the street is probably almost 5 years old at this point. That particular car is local to us and has had no issues with the turbochargers. He's probably put well over 30 or 40k miles on the car. There are a few others out there with high mileage as well. We run them more or less right at peak efficiency, great EGT's, so they should last just as long as a completely stock VTG.
As for fuel..there's two answers. Pump gas (93 octane) and race gas (100+ octane). With the GIAC software we use, we are able to install two separate fuel maps into the ECU. So, for daily driving you can use 93 octane, and for track days or other times, you can use anything higher then 100 octane in our race map.
The HP numbers that I post from our test cars is almost always 93 octane pump gas, unless I specifically mention otherwise.
Let me know if there's any other questions I can answer for you.
Old Jan 26, 2013 | 04:45 AM
  #124
greekm3's Avatar
greekm3 is infamous around these parts
Originally Posted by Tom@Champion
Hi Red...
Hi Tom...what mm inducer is in your VTG?from what i hear is around 47mm...why no something bigger?like 49mm?
Old Jan 26, 2013 | 05:51 AM
  #125
Tiago's Avatar
Tiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to beholdTiago is a splendid one to behold
Originally Posted by w00zy
That's a great question, especially for guys with stock tiptronic
APR tune on stock turbos with race file can reach 1.5bar (with no problems to the Tiptronic)
Protomotive doesn't want to push more than 1.4bar on VTG's and GT30's to be safe on the stock Tiptronic
Recently i found someone that is running 68VTG's on stock Tiptronic, i wonder how much boost he's running and if the 68VTG's are overkill for that set up.
Anyway, With a $300 price difference, 65VTG's from champion are a waste of time and money comparing to the 68VTG's
I like to walk on solid ground so i only will move to upgraded the turbos, after having a tiptronic ESME kit installed.
I still believe that from 100-200 or 200-300 manual is faster
The diference is mainly due to gears number. For speeds up to 200km/h the tip needs less gears, so is faster. Above 200km/h the manual due to its closer gear ratio, keeps the engine closer to hp peak at each upshift which helps alot to beat aero drag.
Old Jan 26, 2013 | 08:44 AM
  #126
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
I ordered the tip kit in the beginning of the year and got the sad news that ESMOTOR doesn't sell the kit anymore. You need to send the transmission and buy a power kit from them.
Old Jan 26, 2013 | 09:33 AM
  #127
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
FVD sell the kit!
Old Jan 26, 2013 | 12:42 PM
  #128
milou's Avatar
milou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond reputemilou has a reputation beyond repute
Originally Posted by GTRNICK
FVD sell the kit!
In exchange to an arm and a leg
Old Jan 26, 2013 | 01:44 PM
  #129
997tttiplux's Avatar
997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute997tttiplux has a reputation beyond repute
Forgot the kidney Milou
Old Jan 26, 2013 | 02:11 PM
  #130
milou's Avatar
True
Old Jan 26, 2013 | 02:16 PM
  #131
GTRNICK's Avatar
Stop chatting rubbish on my thread!
Old Jan 27, 2013 | 08:33 AM
  #132
Procopis's Avatar
Procopis is infamous around these parts
does anyone has any experience of any company that does bigger turbos for gen 2 turbo s with pdk box
Old Jan 27, 2013 | 08:47 AM
  #133
milou's Avatar
CMS did some experiments on gen 2 turbo, i think Tom is the best person to answer that :-)
Old Jan 27, 2013 | 08:49 AM
  #134
GTRNICK's Avatar
I'm afraid you are going to struggle to find someone who can tune this engine and gearbox beyond stage 2 as it is not so strong compared with the gen 1 engine! Still crazy fast with stage 2 mods!
Old Jan 27, 2013 | 09:49 AM
  #135
Procopis's Avatar
Well i thought so as some companies claim the do but no figures given and they dont seem to come back and answer any questions as how did they achieve a figure of 650bhp on a gen2 turbo or turbo s.
