Need experience, A3071 vs A3076's spool
Old Mar 18, 2013 | 02:43 PM
  #31
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
Originally Posted by The Bogg
congrats P!
Can't wait to hear what you think about the Alphas. Hopefully you can get some pump gas performance numbers before going all out with meth etc....
How can you use the .2tt i/cs with alphas? I thought you had to weld on the mushrooms (bovs) to the i/cs?
Thxs Asher!
The "mushrooms" will be on a new Ypipe (my actual Proto Ypipe will be for sale) with no airbox, first I wanted to bolt Evoms inlet pipes and keep my airbox, but it makes the engine less responsive than fenderwell and the diameter at the turbo does not fit the Alphas.
Old Apr 19, 2013 | 06:39 PM
  #32
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
Originally Posted by K24F
Thxs Asher!
Todd knows who has an adapter for the inlet pipes to connect to the alphas
I wonder how much less responsive the engine would be
I think the EVT850 uses, or the 1st one used, the EVOMS inlet pipes and stock airbox
Old Apr 19, 2013 | 07:12 PM
  #33
k-ore's Avatar
k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !k-ore Is a GOD !
Originally Posted by Tony@epl
Honestly, its about the same amount of work to just put on a non alpah 3076 on the 997 and you have more options with turbo configuration.
The chra can be modified to bolt to the oil tanks, and all the oil/water line connections need to be fabricated in the same way (alpha vs non alpha). The exhaust doesn't bolt up like on the 996tt, so its the same amount of work (or less) to fabricate an exhaust for the non alpha 3076's.
Really the only benefit we see around here to the alpha's are they allow you to do is bolt the turbo's to the factory headers, but for the price difference between alpha's vs a standard 3076 will almost buy you a nice set of headers!
I set we recently built for a car we're putting together here at the moment.
Tony,
Can you pm me a price on these headers, for a 996TT fitment? Thx.
Old Apr 20, 2013 | 02:50 PM
  #34
Giorgos Cayman's Avatar
Giorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond reputeGiorgos Cayman has a reputation beyond repute
Originally Posted by k-ore
Tony,
What mm are these headers??
Old Nov 11, 2014 | 06:28 PM
  #35
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Updates
Old Feb 18, 2015 | 09:29 AM
  #36
dhahlen's Avatar
dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !dhahlen Is a GOD !
updates?
Old Feb 18, 2015 | 02:51 PM
  #37
K24F's Avatar
I still don't know the difference in the real life between 3071s and 3076s.
All I can say now (engine rebuilt, 3,8l, E85, cams, 1680ccs, etc...) is I'm totally glad with my turbos, the car is a blast from 3500 to 7000.
Average 60-130 is 5' @1,5Bar (67%IDC) and impossible to raise the boost above until I bolt a stronger clutch! (Actually the strongest Sachs sold by FVD)
Anyway actual cold (dry) roads do not allow to WOT until the 5th gear without lighting the PSM.
Old Feb 18, 2015 | 03:04 PM
  #38
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
You have the 76 now?
Old Feb 19, 2015 | 11:30 AM
  #39
I've used both Alpha3076 and regular T3 HTA3071, i think both are about the same actually. Currently I am using the HTA3071s and they spool very fast.
#TeamAIM
Old Feb 19, 2015 | 08:41 PM
  #40
proTUNING Freaks's Avatar
proTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond reputeproTUNING Freaks has a reputation beyond repute
For your reference, Tial Alpha 3076s on our shop 997.1 hit 20psi at around 3800rpm in 4th gear, pump gas, stock manifolds, stock motor.
Fadi
Oct 5, 2015 12:14 AM
Bmanny
Sep 16, 2015 08:29 AM
Sep 3, 2015 04:56 PM
