What is this?
Old Jan 27, 2013 | 12:42 PM
SUB-ZERO's Avatar
SUB-ZERO has a spectacular aura aboutSUB-ZERO has a spectacular aura about
What is this?
I noticed that the gasket was a bit wet. Also, noticed a bit of oil surrounding that area. Anyone? This is a 997.1 Turbo.
Thanks!
Angel
Old Jan 27, 2013 | 01:38 PM
bbywu's Avatar
Are you sure it's oil? Looks like the water pump housing.
Old Jan 27, 2013 | 01:49 PM
SUB-ZERO's Avatar
Not sure. Here is a better picture.
Old Jan 27, 2013 | 01:53 PM
bbywu's Avatar
The photo above is the connector piece to the water pump housing. It does not appear to be leaking. But there is oil around that area - it may be coated with oil running down from elsewhere?
Old Jan 27, 2013 | 04:32 PM
triblk6spd's Avatar
triblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond reputetriblk6spd has a reputation beyond repute
I had a leak in my new (to me) 997TT and it was ending up in the same basic spot. Its at EVOMS right now. Turns out it was the chain housing seal. BIG job to fix. Obviously motor out. I did decide new plugs, fuel filter, and welded coolant fittings were in order as l9ng as the motor was just sittting there.
Here is what mine looked like... On the brighter side...at least your under body is clean...mine looks like it spent its whole life driving in the Seattle.....
Old Jan 27, 2013 | 06:05 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Looks like you even had oil on the crankcase. Most crankcases don't have a layer of film on them like that.
Chain housing seal, I don't like the sound of that one...
Old Jan 27, 2013 | 07:15 PM
SUB-ZERO's Avatar
Dang....I hope my issue is more mild than that. I don't have a leak just the gasket is moist. Gonna try to get that gasket replaced and see what happens. Wish me luck!!!!!
