PPI and DME needed on PDK? Re:2012 Turbo S
Old Apr 10, 2013 | 04:00 PM
C4SxM5's Avatar
C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !C4SxM5 Is a GOD !
I'm in the process of purchasing a 2012 Turbo S and not sure if a PPI or DME would be useful with this car being a PDK... I'm having a body shop inspect the car for past paint and accident history but will a PPI be needed since its still under warranty and the will the DME be useful on a PDK?
Old Apr 10, 2013 | 05:01 PM
bbywu's Avatar
Just a hypothetical.
Previous owner takes car to track. Uses OEM brake fluid.
After several hours at the track, the aluminum heat shield melts and the internals of the calipers fry. Brake fluid squirts around the seals and burns off when it hit the backing plate on the pads. Brake pads are caking and cracking. Rotors are glazing.
Previous owner trades in car. Your car is under warranty, but often times track damage may not be covered. Not sure your dealership would cover this type of damage under warranty, and you won't know about it without doing some sort of inspection.
For the cost of the vehicle, a proper inspection (even under warranty) is helpful.
Old Apr 10, 2013 | 07:25 PM
CALGUY's Avatar
CALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond reputeCALGUY has a reputation beyond repute
Nice hypothetical.
Old Apr 10, 2013 | 07:59 PM
C4SxM5's Avatar
Point taken. PPI will be done and mind as well get the DME readout.
Old Apr 11, 2013 | 01:36 PM
Dr. Bill's Avatar
Dr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of light
DME not needed with PDK. The computer keeps people from doing damage.
An inspection would be good for peace of mind if nothing else. Even with a CPO car - I've seen a car with aftermarket suspension parts and a small dent get CPO'd. Not sure how, but I made the dealer buy it back.
Old Apr 11, 2013 | 08:01 PM
2swoosh's Avatar
2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future2swoosh has a brilliant future
i think dealer will cover the damage under warranty since you didn't know about it.
Old Apr 11, 2013 | 10:38 PM
C4SxM5's Avatar
So with PDK one can't over rev or mis shift causing engine damage?
Old Apr 11, 2013 | 10:54 PM
arash's Avatar
arash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to beholdarash is a splendid one to behold
It's a lot harder to do. But I still wonder what would happen if you're in first gear going down a steep hill and you never shift...
Old Apr 12, 2013 | 09:42 AM
Dr. Bill's Avatar
Correct. Not even if you try.
Old Apr 12, 2013 | 10:13 AM
bbywu's Avatar
DME scans tell you much more than over revs. If you are paying for a PPI, get a DME scan or run Durametric. It can give you a hint if the car has been flashed. Also tells you operating hours. You can calculate average speed that the car has been driven by the odometer on the speedometer and the operating hours. It will give you a hint if the odometer has been tampered with or has spent time at a track.
You can also use PIWIS2 to see the date stamp on the memory of the control modules - have they been tampered with.
I think that depends on the dealership. I think there are plenty of members here who have had very good "good faith" repairs, and others that have been taken advantage of due to ignorance.
Old Apr 12, 2013 | 07:01 PM
jleeev's Avatar
jleeev is infamous around these parts
Does the DME log 'Launch Control' activity?
J
Old Apr 15, 2013 | 10:45 AM
911xpress's Avatar
911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute911xpress has a reputation beyond repute
Porsche also will CPO a car that has been in an accident. I've seen multiple cases of this when looking at the PUSA website and searching for cars. I assume they are minor fender benders but you never know without full disclosure.
Sales@epl
996 Turbo Vendor Classifieds
Sep 7, 2015 02:05 PM
MrMiggy
Aug 21, 2015 06:55 PM
Phoenix604
Aug 19, 2015 10:39 PM
Aug 19, 2015 06:55 PM
MAcarbon
Aug 19, 2015 04:52 PM
