New Datalog!!!
Old May 2, 2013 | 01:50 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Originally Posted by TTdude
What type of fuel are you using? Looks like some timing being pulled at the end with high load. You should be able to achieve full boost 1.55 bar with your set-up even on 93 (r+m)/2 octane. Better check with FVD.
I'm using 99 ron fuel.
I might have an air leak somewhere but Rhonda took the logs last night and sent them to Germany so lets see what they say anyway.
Old May 2, 2013 | 08:21 AM
Rhonda@FVD's Avatar
Premium Sponsor
Rhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond reputeRhonda@FVD has a reputation beyond repute
earl3, TTdude and bbywu, Nick has 2 trouble codes currently which need to be sorted out, P 2188 and P 2190. Both are Lambda control adaptation FRAU (lower load range) above limit value so he will have to check into the mass air flow sensor, secondary air leak in the intake system, a leak in the exhaust, the fuel pressure / injector or the fuel pump.
Originally Posted by bbywu
What does FVD consider the target AFR for this engine?
Received this answer from FVD Germany - There is no one lineal value for AFR. It is depending of a lot of other parameters. Generally speaking German Tuners says for any Turbo engine good and safe Lambda is between 0.80 and 0.85.
FVD Brombacher - USA
Contact me directly to get the latest FVD forum member discount!
Rhonda Roxburgh
+1-954-571-2050 x 1
rhonda.roxburgh@fvd.net
Visit our online shop for an extensive selection of tuning and original parts www.fvd.net
Old May 2, 2013 | 12:05 PM
bbywu's Avatar
Rhonda - thanks for the update. 0.80 * 14.7 = 11.76, 0.85 * 14.7 = 12.50.
Old May 2, 2013 | 03:48 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Well...in normal circumstances i would keep my opinion for myself...But since opinions were asked i would say that
1)ICs work good
2)Boost is a little low...
3)AFR is slight lean
I suggest to raise boost a little to 1,5 over and 1,3 to redline and tune your afr to 0,82...but tuner sure knows better than me...
Just wondering what 60-130 or 100-200 times you have with that setup?
Old May 2, 2013 | 04:03 PM
bbywu's Avatar
1)ICs work good
Strangly, I thought this at first also. When I first looked at the log on my iPad, I thought lean, but AFRs only get there when he's not not a WOT. During his final run, at 260km/h, his AFRs were 10-11.5ish.
Thoughts?
Old May 2, 2013 | 04:28 PM
earl3's Avatar
earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !earl3 Is a GOD !
Thoughts?
I also noticed some bank to bank AFR variance on the last run. Combined with the 2 codes he's getting, sounds like a leak somewhere.
Old May 2, 2013 | 04:39 PM
GTRNICK's Avatar
As soon I fix this leak/problem I will run some times.
What do you reckon it should be?
GTRNICK's Avatar
Thank you for the input so far!
Old May 2, 2013 | 04:45 PM
Dont mention it...
I suppose a good tune should give you less than 6,5sec for 100-200km...
add around a sec for 60-130mph.
Old May 2, 2013 | 04:47 PM
GTRNICK's Avatar
Dont mention it...
That would be great and with hybrid turbos?
Old May 2, 2013 | 04:49 PM
GTRNICK's Avatar
It's also nice for people to say good things about the intercoolers!
Old May 2, 2013 | 05:58 PM
Talisman013's Avatar
Talisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond reputeTalisman013 has a reputation beyond repute
regarding boost: What is the formula to convert to bar? What is it measuring in?
Old May 2, 2013 | 06:04 PM
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
1 bar= 14.50 psi
At idle it measures 1000 so that would be your zero, if you have 2400 then 2400-1000=1400 which is 1.4 bar 1.4*14.5= 20.3 psi
Old May 2, 2013 | 06:16 PM
Originally Posted by nevert00fast
1 bar= 14.50 psi
Thanks, but isnt it 1.4 * 14.7 20.58psi?
EDIT: nevermind, checked, its 14.5037738
for a very long time I thought 1 bar was the same as atmospheric pressure (14.7)
Old May 2, 2013 | 11:33 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
Dont mention it...
My opinion, good tune < 6s 100-200 km/h, <7s 60-130 mph, full weight, race gas and smooth as stock.
