New Datalog!!!
Old May 3, 2013 | 06:38 AM
  #31
bbywu's Avatar
Originally Posted by Talisman013
Thanks, but isnt it 1.4 * 14.7 20.58psi?
EDIT: nevermind, checked, its 14.5037738
for a very long time I thought 1 bar was the same as atmospheric pressure (14.7)
I think you are getting lambda conversion confused with boost pressure. 14.7 is the stoichiometric conversion of lambda.
Take a look at the sticky I made on the top of this forum, "Tuning with Durametric."
https://www.6speedonline.com/forums/...ic-primer.html
Old May 3, 2013 | 07:28 AM
  #32
nevert00fast's Avatar
nevert00fast is infamous around these partsnevert00fast is infamous around these parts
I think the standard atmospheric pressure is 14.70(14.696) PSI at sea level, since the value is identical with Stoich and so close to 1 bar/14.50 psi it's confusing.
Old May 3, 2013 | 08:23 AM
  #33
bbywu's Avatar
Could be. Usually, I take the measured atmospheric pressure at idle, and subtract that value from the measured pressure during the run. The difference is the additional pressure produced from the turbos.
Since weather, altitude changes the numbers somewhat, the idling pressure seems more accurate to me.
Old May 8, 2013 | 11:01 PM
  #34
AriS4's Avatar
AriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond reputeAriS4 has a reputation beyond repute
I am VERY new to logging (just started to play with it...so excuse anything that sounds OFF) but
target .80 to .85 ?
Isn't that a bit on the ballzy - lean side ?
also looks like timing is having a hard time staying steady (or increasing or not falling off - ie - line 746 and on - could be knocking ? righ arond there the lambas are looking quite high too )
COBB Tuning
Nov 3, 2015 08:39 AM
jyupitt1
Sep 10, 2015 03:56 AM
