Strange noise while turbos are spooling up.
Old May 31, 2013 | 10:28 PM
Jonnydeep83's Avatar
Jonnydeep83 is infamous around these parts
I had some work done on my 2007 997.1tt tip car (engine out to fix coolant leak). I also had the dealership install my EP1 exhaust at the same time. Anyways long story short there is now a strange noise when the turbos spool up. If you are in the car it almost sounds like one of the "party spinning clicking toys", I would describe it as a ratcheting sound (to me it sounds metallic almost). It happens as the car is quickly going from low boost to high boost. The noise did not really persist if I maintain full boost though, it's almost like there it is just when the turbo starts winding up. Speed does not really matter, I can make the issue happen at lower speeds provided I push the boost high quickly. There are no mods to the car other than the exhaust (no tune). Any ideas as to what this might be? I took the car straight back to the dealership but I wanted some second opinions. I took some video of the issue, it's not the best quality and you kind of need to crank the volume to 11 to hear it but maybe someone is familiar w/ this issue and can chime in. BTW, it didn't really seam like there was a loss in boost either (but it has been a while since I have driven the car so maybe I am not the best judge).
http://www.youtube.com/watch?v=W-q2ux5FMRA&feature=youtu.be
<iframe width="640" height="360" src="http://www.youtube.com/embed/W-q2ux5FMRA?feature=player_detailpage" frameborder="0" allowfullscreen=""></iframe>
Old May 31, 2013 | 11:14 PM
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
It almost sounds normal to me, but it's difficult from the video to get a sense of all the different sounds going on (road noise, etc). I think I hear what you're talking about, the Europipe exhaust note is a bit raspier than the factory - I'm hearing some of that. But what you're describing as a ratcheting sound is more than likely a boost leak at the throttle body/plenum area. Could a 'flapping' sound also describe it to you?
Old May 31, 2013 | 11:22 PM
TTdude's Avatar
TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !TTdude Is a GOD !
My guess it's a boost leak. It's not uncommon when installing a new exhaust to accidentally knock a hose loose to the IC.
Old May 31, 2013 | 11:49 PM
Jako's Avatar
Jako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to beholdJako is a splendid one to behold
Will a boost leak throw a CEL? Cause unless it does, how do you really know?
Old May 31, 2013 | 11:54 PM
TTdude's Avatar
No, none specific for a boost leak. If there are no fault codes, then diagnose by symptoms/history. First thing to do is check boost hoses.
Old Jun 1, 2013 | 12:31 AM
speed21's Avatar
Couldn't really hear any ratcheting or clicking and clip was so short and contaminated with other sounds but if i was to make anything out of it, it as as others say, boost leakage somewhere. Did you take the I/C's off or any hoses when installing?
COBB Tuning
Jan 1, 2025 09:02 AM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Senatorblutarsky
Aug 28, 2015 12:44 PM
