Lowering my '07 .1TT
Old Jun 8, 2013 | 05:35 AM
ysfg35's Avatar
ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !ysfg35 Is a GOD !
Used eibach lowering kit on my turbos !
Looks very great with zero issues ! Dealer shop did the installation !
Old Jun 8, 2013 | 09:22 AM
aa909's Avatar
aa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond reputeaa909 has a reputation beyond repute
I've installed the GMG springs and am very happy with the improvement in stance as well as the ride quality, especially in normal mode. From my experience the springs impact the rebound rate over bumps and the leaning or listing during turns but it is the shocks that really define the stiffness.
This becomes evident in sports mode because even with the GMG springs the stock shocks are so stiff in sports mode that they dominate the overall experience.
To put it another way, aftermarket springs like GMG, H&R or eibach should all improve the ride quality in normal mode by eliminating the "bobbing" sensation from the mushy stock springs, but in sports mode the ride feel is dominated by the stiff stock shocks and you won't notice a huge difference over the stock springs
Either way get some aftermarket springs if for no other reason than to lower the car, stock ride height is for SUVs
Hope this helps
Art
Old Jun 8, 2013 | 11:12 AM
cannga's Avatar
Art, this is an excellent analysis and in a few sentences you've actually given me a very very good "glimpse" into the GMG spring's behavior.
I would like to add the following: true, the shock would define the stiffness, but only if you let it to. Both springs and dampening force define stiffness. In other words,
If a is spring rate, b is dampening force, then, as a gross simplification:
a + b = "stiffness"
If either a or b is off the chart, in this case b (the flaw design of Sport mode in PASM gen 1), there is nothing you could do with the spring to reduce the stiffness.
The only way to truly get rid of the problem with PASM gen 1 is of course to switch to a coilover.
In the stock shock, the damping force is set (seemingly) at 1 for Normal mode, and 10 for Sport mode (making this mode mostly un-useable).
In Bilstein Damptronic shock, the damping force is set more like 4-5 for normal mode, and 6-7 for Sport mode. (This is why people new to the Damptronic sometimes think there is no difference between the 2 modes. There is.)
BTW, a couple things for OP to consider: GMG and Techart springs are stiffer than stock, whereas H&R's ride very similar to stock. If you are looking to stiffen the chassis, GMG and Techart are good choices, and H&R would become stiffer only if you add other components to stiffen the system such as sway bar, drop link, etc.
Another point to consider is that all lowering springs drop the ride height a fixed 1 inch, whereas coilover drop is adjustable (I would recommend only 10-15mm so there is not too much change to the suspension 3D geometry.).
Old Jun 8, 2013 | 11:23 AM
aa909's Avatar
^^^^^ cannga. Good clarification as my comments were specific to the combination of aftermarket springs with stock shocks in sports mode.
At the end of the day aftermarket springs are likely not going to "soften" the feel of the ride in a 997.1 TT in sports mode as the stiffness of this setting is a 10 out of 10 and requires different shocks to modify the ride feel
However with that in mind the GMG springs are excellent if you want to lower the ride and improve the feel and handling in normal non-sports mode while not messing with the rest of the suspension
Art
Old Jun 9, 2013 | 12:54 PM
LeoLambo's Avatar
Lamborghini Fanatic
LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !LeoLambo Is a GOD !
Originally Posted by Fugazi
Serious Autosports here in WPB I also just ordered my Switzer 650 kit that's why I got that price.
That's s great deal! I'm calling them in Monday!
Old Jun 9, 2013 | 06:54 PM
Choy's Avatar
Choy is infamous around these parts
H&R works for me
Old Jun 11, 2013 | 08:47 PM
LT1's Avatar
LT1
LT1 is infamous around these parts
H & R here. Great stance and stock like driveabilty
Old Jun 11, 2013 | 09:02 PM
blackbull's Avatar
blackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond reputeblackbull has a reputation beyond repute
Originally Posted by Tom@Champion
We use H&R springs pretty much exclusively for the 997 Turbo. Over the past 6 or 7 years we've probably installed over 100 sets of them on PASM-equipped cars and have never heard a complaint. The ride in non-sport is very compliant and comfortable, maybe just a tad firmer then stock. Switch to sport mode and they're aggressive and firm. Typically, we do the whole job...cost of springs, installation, and complete alignment for around $1150.
Here's a few pics of cars we've done to give you an idea of what the stance is like:
STILL way too high!!
Old Jun 11, 2013 | 09:17 PM
LeoLambo's Avatar
Lamborghini Fanatic
It's high but they give you warranty!
Old Jun 12, 2013 | 09:27 AM
ilko's Avatar
ilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of lightilko is a glorious beacon of light
H&R here. Handling improved, ride quality didn't change. The flaps on the front wheel liners scraped over bumps so I cut them off. Car feels great:
Old Jun 13, 2013 | 07:56 PM
eas's Avatar
eas
eas is a splendid one to beholdeas is a splendid one to beholdeas is a splendid one to beholdeas is a splendid one to beholdeas is a splendid one to beholdeas is a splendid one to behold
+1 for GMG springs, do their sways at the same time!
Old Jun 13, 2013 | 10:35 PM
drsullivan's Avatar
drsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant futuredrsullivan has a brilliant future
Originally Posted by Porsche997TT
What do I need to properly lower my '07 .1TT? What parts/brands?
Looking to get rid of the 4x4 look. And have a nice squat at the rear.
Just got my car back from EVOMS lowered, sways, and aligned. I posted some pics - same link as post #2
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
Stuart@VelocityAP
Sep 23, 2015 05:30 PM
