Throttle reset
Old Oct 28, 2013 | 05:49 PM
cerbomark's Avatar
cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !cerbomark Is a GOD !
Thanks for the post.
Reset mine although it was fine.
I hear the adjustment being made at 30 sec (during the first 60 sec cycle) and then again during the 15 sec cycle.
Old Oct 29, 2013 | 12:48 PM
SFZGT3's Avatar
SFZGT3 is infamous around these parts
Hi, all. I was hard(ly) at work when I clicked over to this thread from the 997 forum. I have a new to me 2007 997.1 C2S, runs awesome, no issues. However, if I ever did start experiencing the "sensitivity" symptoms, would this procedure apply to my car as well? I realize you are all talking about .2 Cars and TT's, so I wanted to ask if there is a similar or identical procedure for my gen.
TIA for your answers.
Old Jun 8, 2016 | 09:36 AM
cerbomark's Avatar
Just tried this on my 2015 Panamera and thought I heard it resetting. Can anyone confirm it s the same procedure ? Thanks.
Old Jun 8, 2016 | 12:56 PM
kkswow12's Avatar
kkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nicekkswow12 is just really nice
interesting and timely...to me
i have just changed out the heavy clutch helper spring under the dash, replaced it with a much lighter spring, per the thread in the 996 forum, and after doing this i have had the same problem,twitchy throttle, maddening, but only when the car is cold, at first i thought it was me, but it is really pronounced....goes away when she warms up...very strange, i will do this throttle reset tonight and see if it makes a diff....and if anyone is interested, it is an amazing difference in clutch action with the different spring...i was stalling the car when starting from being at rest on a regular basis, and i am really not a bad driver but could never get in sync with my car, HOWEVER .....THIS HAS MADE ALL THE DIFFERENCE...i can drive again...! like..... normal, anyway, i will let you all know if the throttle reset helps, and thanks for the info, i hope it works!
Originally Posted by TAILWAG
I have the opposite problem..mine is simply too responsive, even on non-sport mode. Any fix for this?
Old Jun 8, 2016 | 08:57 PM
Bobbyfali's Avatar
Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !Bobbyfali Is a GOD !
Originally Posted by The Bogg
It may be the way it's tuned. Check with EVOMS. When I first put on the Proto flash I thought the throttle response was a little twitchy, especially in sport mode. However, the same flash was perfect for the upgraded vtgs, and I can even drive in town in sport mode without lurching.
That is exactly what it is.
Give Todd K a call and he can most likely adjust the pedal to be less sensitive (kind of like a Sprint Booster).
Old Jun 9, 2016 | 07:59 AM
997TTEQNY's Avatar
997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future997TTEQNY has a brilliant future
Did this last night, and the results are pretty good
better throttle response off the line, and between downshifts.
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
007 Vantage
Oct 8, 2015 08:35 PM
