Independant Intercooler Test
Subscribe
Nov 5, 2013 | 10:09 PM
  #151
Interesting results. I wonder why 9 m/s is the fastest airflow measured? Barely 20mph.. aren't the ICs seeing considerably more than that? As in, at 100+mph (where the heat becomes an issue), they're seeing 100+mph airflow through the core?
I'm converting knowledge of radiators for water cooled PCs here, but generally at lower airflow speed, lower density cores (ie .2s) way outperform higher density cores (proto/tpc, champion, AMS). Yet when you get good airflow with higher static pressure (as would be caused by the ducting vs having these open air as in this test), the higher density cores come alive and completely dominate the low density ones.
So while this is a fantastic data point, to me it seems somewhat pointless b/c the air was so slow across the cores. Nobody has issues with cooling at 20mph right? Or am I missing something (entirely possible)?
Reply
Nov 5, 2013 | 11:45 PM
  #152
Quote: Thanks Nick for doing this. A few thoughts:
1) You tested a group of really good intercoolers, one should not think of the fvd as a low performer by any means. I really wish you could have gotten a 3.5" bell core in the mix as it is probably the most common aftermarket core and would have given an aftermarket baseline, disappointing few would play. Same with a .1 core.
2) The gt2 rs cooler flow myth is debunked yet again. Thats still an acceptable delta p at over 700 hp worth of airflow.
3) Do you have any pics of the test setup? The 9 m/s if cooling airflow may not be a simple as it seems. If they were able to maintain that across the core, it may be more realistic that we think. Anyone know the air velocity across the core installed in the car running at various speeds? With the backpressure from the outer core itself, it may be much lower than the car's speed. Just curious if they know something more here as I'm impressed the efficiency is as high as it is at .3 kg/s of charge flow!
4) I've never had good luck with those inlet/outlet temp gauges on automotive apps. They are good in airplane apps where you're at steady state for hours but imo, way too slow to capture useful data over the span of 10 to 20 seconds where most of these in car intercooler tests take place. Maybe theyre much faster now though...
Thanks Earl.
1)It is a shame more cores were not added to this test but that's not to say it can still be replicated if people still have a change of heart and still want to test their cores as it can be repeated over and over again.
2)yes the Gt2 core for the money and its capabilities is a no brainier but still will hit a brick wall at some point.
3)Yes they were able to maintain that speed across the core and no I don't have any pics but will ask if they are willing to take some for me.
4)This is what I have found out myself is that these monitoring systems will not read the airflow fast enough for the testing I want to do and dura metrics would be far more superior as the car ECU reads so much faster.
Reply
Nov 6, 2013 | 12:01 AM
  #153
Quote: Interesting results. I wonder why 9 m/s is the fastest airflow measured? Barely 20mph.. aren't the ICs seeing considerably more than that? As in, at 100+mph (where the heat becomes an issue), they're seeing 100+mph airflow through the core?
Right the airflow can only be set to 15m/s.
The issue if you call it one was the the motor used to pump the air was struggling to push air through the high density cores so I asked them to pick the max air flow they could achieve with the most dense core to make it a fair test as its no good running one at 10m/s or 12m/s because then the figures would be all over the place. In regards to the higher speeds at 100mph yes you would see a lot more cooling with the denser cores the gap between the 3 coolers tested would just keep growing!
It's not completely pointless no.
You still get a chance to see which is the better cooler out of the bunch tested.
Okay you do not see max capabilities which you get from reality testing but you sure do get a good idea of what is working better than the other.
You know already from your PC knowledge the higher density cores will win as the airflow climbs.
What would make it even more interesting is if we could add a few more to the mix.
Reply
Nov 6, 2013 | 12:08 AM
  #154
Quote: Anyone know the air velocity across the core installed in the car running at various speeds? With the backpressure from the outer core itself, it may be much lower than the car's speed.
Now this is the question. ICs' location is far from optimal, at least compared to those in front of the car.
When building mine and planning the placement of / ducting to ICs (narrowbodied car) I discussed about the issue with factory trained Porsche Center head-of-maintenace. He claimed that most of the flow across ICs is caused by the vacuum at outlets than overpressure at inlets... Which aren't exactly in an overpressure area on the side of the car. Although the rear fender's shape has an effect here.
As an idea of the issue here's example pics of CFD simulation:
Switzerland-based MATECH Competition relied on Exa Corporation’s PowerFLOW CFD software to make its Ford GT1 race car more aerodynamic.
Another picture here: http://www.flickr.com/photos/jalopnik/422044058/lightbox/
AIR PRESSURE COMPARISON FRONT VIEW - Generated by Computational Fluid Dynamics (CFD), this illustration compares the aerodynamic characteristics of the NASCAR Impala SS (foreground) and the Monte Carlo SS (rear). The colors on the body surfaces represent relative pressure, from red (highest) to green (moderate) to blue (lowest). Similarly, the colors of the streamlines around the cars indicate the pressure in the surrounding air from red (high pressure) to blue (low pressure). High pressure on the nose and headlights of the Monte Carlo SS shows that this area generates the majority of the car's front downforce; this area is blue on the Impala SS, indicating low pressure and lift. Dark red on the horizontal surface of the Impala SS's front splitter shows that this aerodynamic device generates significant downforce. NASCAR allows the splitter to be adjusted from four to six inches ahead of the bumper recess to fine tune the aerodynamics. (General Motors Racing Handout) (USA)
CFD Air Pressure Model
The GT2-spec Corvettes were designed, built and tested on a compressed schedule. The program was approved and announced in September 2008, and construction of the first chassis began in early December. The first track test was conducted at Road Atlanta on April 8-9, followed by single-car tests in Elkhart Lake, Wis., and Sebring, Fla. Doug Fehan, Corvette Racing manager said "The Corvette Racing team had to take on several challenges simultaneously to execute this program." He added "We were preparing for our regular race season with the GT1 cars while designing the GT2 version. The cars were being built and tested in the midst of our preparations for Le Mans. The team was multi-tasking to the extreme, operating on a leaner budget and a faster timeline. It was a monumental effort to have these cars ready for the Mid-Ohio race."
GT3_Total_Pressure_web-300x210.jpg   GT1.jpg   GT3_Total_Pressure_web-300x210.jpg   GT1.jpg   GT2CFDAirPressure.jpg
Reply
Nov 6, 2013 | 12:22 AM
  #155
Quote: He claimed that most of the flow across ICs is caused by the vacuum at outlets than overpressure at inlets... Which aren't exactly in an overpressure area on the side of the car.
That's true. It's a venturi tube.
Very nice flow pictures
Andreas
Reply
Nov 6, 2013 | 12:25 AM
  #156
Andreas
+1
Great info Pete thanks.
Reply
Nov 6, 2013 | 01:03 AM
  #157
Interesting results....one thing that caught my eye as particularly interesting is this:
One the "Cooling Side" the outlet temps for both the Aero and GT2RS cores were virtually identical but on the "Charge Side" there was a consistant 3-4 degree advantage to the Aero cores.
So with that information we can deduct that the same temp of heat was being transfered on the "cooling side" but there was a efficiency on the "charge side" coming from somewhere. With an almost identical pressure drop on the charge side, the Aero core seems to get its advantage by the pressure delta on the "cooling side" from a denser core?
Reply
Nov 6, 2013 | 01:06 AM
  #158
Quote: Now this is the question. ICs' location is far from optimal, at least compared to those in front of the car.
It would be interesting to see what the velocity of the air is in the inlets and makes me even more curious if the ducting that companies like AMS have really adds an advantage in vaccum.
Reply
Nov 6, 2013 | 01:07 AM
  #159
Quote: Interesting results....one thing that caught my eye as particularly interesting is this:
Exactly.
You know your stuff aye. In fact a hell of a lot more than I do as you have studied this kind of stuff.
The reason you can get away with the higher density is down to the special fin design of the aero!
To have this kind of fin density in conventional cores would mean to much heat build up on the cooling side due to the pressure drop?
From what I have learnt or assume.
Reply
Nov 6, 2013 | 05:25 AM
  #160
GTRNICK .... I can see you are on a IC mission. Find yourself a copy of A. Graham Bell's book, Forced Induction and Tuning. There is an extremely good chapter on intercooler science. What works, doesn't work so well and why.
Reply
Nov 6, 2013 | 07:24 AM
  #161
Quote: GTRNICK .... I can see you are on a IC mission. Find yourself a copy of A. Graham Bell's book, Forced Induction and Tuning. There is an extremely good chapter on intercooler science. What works, doesn't work so well and why.
cheers CJ
Holy smokes they are £200
Ill order one
Reply
Nov 6, 2013 | 08:55 AM
  #162
Ill order one
About five years ago I paid under $50.00 for mine. I saw a copy in very good condition on the alibris website for about $150.00 plus shipping.
Reply
Nov 6, 2013 | 09:05 AM
  #163
I just bought one for £128.50 lol.
I think I might buy a few more seem like a good investment ;-)
Reply
Nov 15, 2013 | 03:33 PM
  #164
Nice work, thanks for taking the time to do this!
Reply
Nov 15, 2013 | 03:49 PM
  #165
Quote: Nice work, thanks for taking the time to do this!
It was my pleasure.
Reply
