Independant Intercooler Test
Old Oct 27, 2013 | 09:55 AM
  #106
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Originally Posted by 93ls1rx7
Let me clarify a few things about this test from my perspective.
1. I actually do applaud Nick for doing this. (despite what my earlier posts may imply)
Cheers I appreciate the kind words. (What happend did you get layed last night? Joke)
2. I would have no issue with Nick if he would have said I am taking my core and any others and if mine stacks up I may consider marketing it.
I will choose not to respond to this as it won't get us anywhere.
3. As far as the actual test I still would have liked to see a couple things:
A. Testing the cores in space in the wind tunnel, not mounted in the car is flawed. I think this does a disservice to the cores. While one may flow best in a "straight line" we all know the intercooler is at an angle and the air needs to turn to get to it. I would love to see the testing done in the car. This can seriously reduce the velocity across the core and make better flow irrelevant because the core wont ever actually see that type of velocity.
No matter what you say here you are wrong about the test being flawed but you are entitled to think the way you do.
The reason you are wrong is all 3 coolers being tested are being given the same variables on the same day in the same tunnel. So explain in detail how that is a flawed test please?
B. I would have liked to see different intercooler ducting like the AMS design. While their intercooler fin design may or may not decrease IAT by 5 degrees less in a straight line, their intake in the car could cancel that out and actually make it a 5 degree GREATER decrease. Does modifying (cutting) the ducting cause worse flow and ultimately worse performance even if the actual fin design is more efficient.
ANY data is good to have but in my opinion the closer you can get to car conditions the better and more relevant it is going to be.
What you have said in 3.A & 3.B is absolutely right in terms how they will perform in the car will be different to them performing in the tunnel but wether they are tested in the tunnel or the car you will see the differences is my point. Plus the variables which are chosen to be used are going to be as close to reality as possible.
The advantage of the tunnel is that you can replicate the same test over and over again till you are sick of testing but in the real world you know very well you cannot therefore the real world testing of one cooler vs another could be flawed or less accurate as the temps could change the pressure could change the wind speed could change and so on!
I hope this explains the test a bit better to you.
Cheers,
Nick.
Old Oct 27, 2013 | 10:01 AM
  #107
GTRNICK's Avatar
This quote is from the day I tested them with durametrics which dead on 1 year ago next month!
"Here's some result I have lots of logs but I though I would just post the result's that mean something.
Test has been done on the same day within the space of 5hrs
Stock coolers.
<OEngine speed/ Intake Temp/Ambient temp/Vehicle speed
6226.5 / 44c / 11.3c / 237.4kmh
<OAerospace coolers.
<OEngine speed/ Intake Temp/Ambient temp/Vehicle speed<O</O
6377.5 / 29c / 13.5c / 237.4kmh
<O6476.5 / 37c / 14.3c / 300.24kmh<O</O"
Old Oct 27, 2013 | 02:26 PM
  #108
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Holy smokes those "Aerospace Core" intercoolers are $9,000?
Old Oct 28, 2013 | 11:13 AM
  #109
cannga's Avatar
Hi Nick, sorry I haven't found exactly which intercooler you'll be testing, but is the stock 997.1 Turbo's intercooler included in the test? I think it might provide a useful frame of reference. For example, if your test shows no difference between stock 997.1 Turbo's intercooler and GT2 RS's intercooler, that would mean the test may not be tracking the parameter you are looking for.
In other words, you hope to see difference between 2 intercoolers that are expected to be different. How big the difference is between other intercoolers against stock will also provide a useful frame of reference. Good luck with the test; very curious to see what you'll find.
Old Oct 28, 2013 | 11:20 AM
  #110
GTRNICK's Avatar
Originally Posted by cannga
Hi Nick, sorry I haven't found exactly which intercooler you'll be testing, but is the stock 997.1 Turbo's intercooler included in the test? I think it might provide a useful frame of reference. For example, if your test shows no difference between stock 997.1 Turbo's intercooler and GT2 RS's intercooler, even that will be a useful data point.
Bear in mind I'm not paying for FVD's test and it's costing me a good $4000 already. I don't fancy paying anymore right now lol. But I do know from a good source Porsche claim a good 8% increase over stock.
If you guys want to chip in on a separate test I'm willing to organise this for you. The good thing is I will already have the gt2 rs data for you.
Old Oct 28, 2013 | 11:34 AM
  #111
cannga's Avatar
Got it somehow I thought it was a one-price-for-everything LOL. :-) Wow $4000 for how many intercoolers tested, which ones on the final list?
The 8% above is what I meant: your test will prove to be valid if it is *consistent* with a known entity, in this case the 8% that Porsche claims. If it doesn't show any difference then you know what you are measured may not be *that* applicable or relevant. Especially if you are going to commercialize this project (which I don't have any problem with, good for you) then IMHO a frame of reference against stock is important. But, I understand the $ issue and your effort is appreciated regardless.
Old Oct 28, 2013 | 03:31 PM
  #112
GTRNICK's Avatar
Each core is around $1350 to test. I'm paying for 2 and FVD is paying for 1.
Another thing is I am also having the aerospace core decontaminated so it is as new and also to make it a fair test which is another $600. Then because I am doing this I also have to get my other core decontaminated as I am someone who doesn't do things in halves which is another $600 so in total I'm spending $3900 and FVD are spending $1350.
Now in regards to the gen 1 core I did think of testing it as well to cover all angles but IMO for me its just not worth it. People are happy with the GT2 RS as the benchmark as people still buy them and have proved from the logs they are a better choice over stock many times.
Cheers for your kind words Cannga.
I dropped the coolers off today so in the next few days I should have some decent info.
Old Nov 1, 2013 | 05:11 PM
  #113
GTRNICK's Avatar
A Quick update I will post the data when I receive it next week but the Aerospace core came 1st followed by the GT2 RS and last was the AKG's.
Some interesting results.
Old Nov 1, 2013 | 05:23 PM
  #114
GTRNICK's Avatar
Originally Posted by GTDeuce
Nick did they take in consideration volume and pressure loss at a certain volume or temps alone ?
Tks !
<table width="1700" style="width: 1280pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0"><colgroup><col width="89" style="width: 67pt; mso-width-source: userset; mso-width-alt: 3254;" span="9"><col width="98" style="width: 74pt; mso-width-source: userset; mso-width-alt: 3584;"><col width="89" style="width: 67pt; mso-width-source: userset; mso-width-alt: 3254;" span="5"><col width="89" style="width: 67pt; mso-width-source: userset; mso-width-alt: 3254;"><col width="89" style="width: 67pt;" span="3"><tbody><tr height="20" style="height: 15pt;"><td width="89" height="20" class="xl111" style="border: 0px windowtext; width: 67pt; height: 15pt; background-color: white;"></td><td width="178" class="xl112" style="border: 0px windowtext; width: 134pt; background-color: white; mso-ignore: colspan;" colspan="2">This is from a sample report they sent me.
Cooling Air Side
</td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="187" class="xl112" style="border: 0px windowtext; width: 141pt; background-color: white; mso-ignore: colspan;" colspan="2">Charge Air Side</td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl113" style="border: 0px red; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td><td width="89" class="xl111" style="border: 0px windowtext; width: 67pt; background-color: white;"></td></tr><tr height="20" style="height: 15pt;"><td height="20" class="xl111" style="border: 0px windowtext; height: 15pt; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">Mean</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Air</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Inlet</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Out </td><td class="xl111" style="border: 0px windowtext; background-color: white;">Air dP</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">Mass</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Mass</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Inlet</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Inlet</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Outlet</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Charge</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Intercooler</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Heat</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Heat</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td></tr><tr height="20" style="height: 15pt;"><td height="20" class="xl111" style="border: 0px windowtext; height: 15pt; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">Face Velocity</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Mass</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Temp</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Temp</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Static Wall</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">Flow</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Flow</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Pressure</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Temp</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Temp</td><td class="xl111" style="border: 0px windowtext; background-color: white;">dP</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Effeciency</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Duty</td><td class="xl111" style="border: 0px windowtext; background-color: white;">Rejection</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td></tr><tr height="20" style="height: 15pt;"><td height="20" class="xl111" style="border: 0px windowtext; height: 15pt; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td></tr><tr height="23" style="height: 17.25pt; mso-height-source: userset;"><td height="23" class="xl111" style="border: 0px windowtext; height: 17.25pt; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">(m/s)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kg/s)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(°C)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(°C)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(Pa)</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl114" style="border: 0px blue; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kg/hr)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kg/s)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kPa Abs)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(°C)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(°C)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kPa)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(%)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kW/ETD)</td><td class="xl111" style="border: 0px windowtext; background-color: white;">(kW)</td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td><td class="xl111" style="border: 0px windowtext; background-color: white;"></td></tr></tbody></table>
Old Nov 1, 2013 | 05:32 PM
  #115
GTRNICK's Avatar
Here is a data log I took of the aerospace cores.
Car had stage 2 mods.
File Type: pdf
Old Nov 1, 2013 | 05:39 PM
  #116
GTRNICK's Avatar
If you compare it with this datalog from another thread.
Originally Posted by skandalis447
<table width="288" border="0" cellspacing="0" cellpadding="0"><colgroup><col width="72" style="width: 54pt;" span="4"><tbody><tr height="17" style="height: 12.75pt;"><td width="72" height="17" class="xl23" style="width: 54pt; height: 12.75pt;">997,1 IAT</td><td width="72" class="xl23" style="width: 54pt;">SPEED</td><td width="72" class="xl23" style="width: 54pt;">997,2 IAT</td><td width="72" class="xl23" style="width: 54pt;">SPEED</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" class="xl22" style="height: 12.75pt;">AMB=20</td><td>
</td><td class="xl22">AMB=16</td><td>
</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">24</td><td align="right">95,09</td><td align="right">20</td><td align="right">86,93</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">24</td><td align="right">95,38</td><td align="right">20</td><td align="right">89,95</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">24</td><td align="right">96,9</td><td align="right">20</td><td align="right">94,15</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" class="xl22" style="height: 12.75pt;">24</td><td align="right" class="xl22">99,84</td><td align="right" class="xl22">20</td><td align="right" class="xl22">99,15</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">25</td><td align="right">104,12</td><td align="right">20</td><td align="right">103,59</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">25</td><td align="right">108,54</td><td align="right">20</td><td align="right">107,98</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">25</td><td align="right">112,8</td><td align="right">20</td><td align="right">112,21</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">26</td><td align="right">116,66</td><td align="right">20</td><td align="right">115,66</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">26</td><td align="right">120,31</td><td align="right">20</td><td align="right">119,47</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">27</td><td align="right">123,05</td><td align="right">20</td><td align="right">122,32</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">28</td><td align="right">125,49</td><td align="right">20</td><td align="right">124,57</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">29</td><td align="right">136,63</td><td align="right">20</td><td align="right">127,44</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">30</td><td align="right">139,88</td><td align="right">20</td><td align="right">130,36</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">31</td><td align="right">142,94</td><td align="right">20</td><td align="right">133,8</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">32</td><td align="right">145,71</td><td align="right">21</td><td align="right">137,1</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">32</td><td align="right">148,63</td><td align="right">22</td><td align="right">140,39</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">33</td><td align="right">151,77</td><td align="right">22</td><td align="right">143,52</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">35</td><td align="right">154,78</td><td align="right">23</td><td align="right">146,67</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" class="xl22" style="height: 12.75pt;">35</td><td align="right" class="xl22">157,65</td><td align="right" class="xl22">23</td><td align="right" class="xl22">149,7</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">35</td><td align="right">160</td><td align="right">23</td><td align="right">152,76</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">37</td><td align="right">162,98</td><td align="right">24</td><td align="right">155,41</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">38</td><td align="right">165,63</td><td align="right">25</td><td align="right">158,32</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">38</td><td align="right">168,2</td><td align="right">25</td><td align="right">161,29</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">39</td><td align="right">170,57</td><td align="right">26</td><td align="right">0,16</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">41</td><td align="right">173</td><td align="right">29</td><td align="right">180,43</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">41</td><td align="right">175,41</td><td align="right">29</td><td align="right">182,7</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">42</td><td align="right">177,91</td><td align="right">29</td><td align="right">184,67</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">44</td><td align="right">180,16</td><td align="right">30</td><td align="right">186,59</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">44</td><td align="right">182,19</td><td align="right">30</td><td align="right">188,63</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">45</td><td align="right">184,37</td><td align="right">31</td><td align="right">190,41</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">47</td><td align="right">186,57</td><td align="right">31</td><td align="right">191,88</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">47</td><td align="right">188,55</td><td align="right">32</td><td align="right">193,59</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">47</td><td align="right">190,52</td><td align="right">32</td><td align="right">195,32</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">48</td><td align="right">192,48</td><td align="right">32</td><td align="right">197,34</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">50</td><td align="right">193,92</td><td align="right">32</td><td align="right">199,29</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" class="xl22" style="height: 12.75pt;">50</td><td align="right" class="xl22">195,43</td><td align="right" class="xl22">33</td><td align="right" class="xl22">201,24</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">50</td><td align="right">196,96</td><td align="right">34</td><td align="right">203,09</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">51</td><td align="right">198,77</td><td align="right">35</td><td align="right">204,78</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">52</td><td align="right">200,79</td><td align="right">35</td><td align="right">206,63</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">53</td><td align="right">202,15</td><td align="right">35</td><td align="right">208,62</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">53</td><td align="right">203,84</td><td align="right">36</td><td align="right">210,18</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">54</td><td align="right">205,57</td><td align="right">37</td><td align="right">211,9</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">55</td><td align="right">207,3</td><td align="right">37</td><td align="right">213,67</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">55</td><td align="right">208,48</td><td align="right">38</td><td align="right">215,05</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">56</td><td align="right">210,18</td><td align="right">38</td><td align="right">216,77</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">56</td><td align="right">211,96</td><td align="right">39</td><td align="right">218,41</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">57</td><td align="right">213,34</td><td align="right">39</td><td align="right">220,14</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">57</td><td align="right">214,59</td><td align="right">40</td><td align="right">221,49</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">58</td><td align="right">216,52</td><td align="right">40</td><td align="right">223,09</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">59</td><td align="right">217,67</td><td align="right">41</td><td align="right">224,7</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">59</td><td align="right">219,61</td><td align="right">41</td><td align="right">226,2</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">59</td><td align="right">220,59</td><td align="right">41</td><td align="right">227,78</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">59</td><td align="right">222,45</td><td align="right">42</td><td align="right">229,05</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">60</td><td align="right">223,59</td><td align="right" class="xl22">42</td><td align="right" class="xl22">230,47</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">61</td><td align="right">224,91</td><td align="right">43</td><td align="right">232,05</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">62</td><td align="right">226,37</td><td align="right">44</td><td align="right">233,45</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">62</td><td align="right">227,53</td><td align="right">44</td><td align="right">234,93</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">62</td><td align="right">229,17</td><td align="right">44</td><td align="right">236,21</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" class="xl22" style="height: 12.75pt;">63</td><td align="right" class="xl22">230,29</td><td align="right">45</td><td align="right">237,62</td></tr><tr height="17" style="height: 12.75pt;"><td height="17" align="right" style="height: 12.75pt;">63</td><td align="right">231,58</td><td align="right">45</td><td align="right">238,88</td></tr></tbody></table>
Old Nov 2, 2013 | 09:37 AM
  #117
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
Nick my computer is showing your .pdf as having a virus. Any chance you could post the results if possible?
Old Nov 2, 2013 | 12:43 PM
  #118
GTRNICK's Avatar
RPM KMH IAT AMB
<table width="313" style="width: 236pt; border-collapse: collapse;" border="0" cellspacing="0" cellpadding="0"> <colgroup><col width="66" style="width: 50pt; mso-width-source: userset; mso-width-alt: 2413;"> <col width="1" style="width: 1pt; mso-width-source: userset; mso-width-alt: 36;"> <col width="99" style="width: 74pt; mso-width-source: userset; mso-width-alt: 3620;"> <col width="38" style="width: 29pt; mso-width-source: userset; mso-width-alt: 1389;"> <col width="109" style="width: 82pt; mso-width-source: userset; mso-width-alt: 3986;"> <tbody><tr height="20" style="height: 15pt; mso-height-source: userset;"> <td width="66" height="20" align="right" style="border: 0px black; width: 50pt; height: 15pt; background-color: transparent;">2542</td> <td width="1" style="border: 0px black; width: 1pt; background-color: transparent;"></td> <td width="99" align="right" style="border: 0px black; width: 74pt; background-color: transparent;">114.55</td> <td width="38" align="right" style="border: 0px black; width: 29pt; background-color: transparent;">22</td> <td width="109" align="right" style="border: 0px black; width: 82pt; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2523.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">114.81</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2531.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">115.13</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2548.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">115.56</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2559.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">115.98</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2575.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">116.57</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2585.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">117.25</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2595.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">118.01</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2641</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">118.67</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2653.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">119.53</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2648.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">120.58</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2677</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">121.32</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2710</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">121.96</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2721.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">122.91</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2751.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">123.78</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2767.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">124.73</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2771.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">125.44</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2800</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">126.52</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2820.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">127.39</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2835</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">128.41</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2866.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">129.14</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2875</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">130.26</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2913</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">131</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2931.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">132.03</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2946.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">132.66</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2971</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">133.8</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">2975</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">134.8</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3011.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">135.45</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3025.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">136.57</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3034.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">137.63</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3076.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">138.21</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3082.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">139.41</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3115.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.11</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3089</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.02</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3084.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.85</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3259.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.9</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3060.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.63</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3820.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.38</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3750.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.69</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3769</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.49</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3817.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.17</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3832.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.65</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">18</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3837.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.26</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3820.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.86</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3479.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.84</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">3310.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.94</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4651</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.8</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4532.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.73</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4604.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.55</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4610.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.39</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4628.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">140.73</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4652.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">141.08</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4701.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">142.57</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4735.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">143.26</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4769</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">144.13</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4812.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">144.9</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4831.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">145.98</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4856.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">147.18</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4931.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">148.41</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4983</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">150.26</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5058.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">152.22</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5149.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">154.53</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5227.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">156.8</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5345.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">159.76</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5426.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">162.29</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5450</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">164.05</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5524.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">166.33</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5594</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">168.34</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5636.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">170.08</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5736.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">171.98</td> <td align="right" style="border: 0px black; background-color: transparent;">21</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5834.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">174.38</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5863</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">175.99</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5905.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">178.08</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5986.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">179.99</td> <td align="right" style="border: 0px black; background-color: transparent;">22</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6021</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">181.68</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6103.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">183.53</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6122.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">185.2</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6171.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">186.79</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6273.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">188.73</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6294</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">190.31</td> <td align="right" style="border: 0px black; background-color: transparent;">23</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6359.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">191.79</td> <td align="right" style="border: 0px black; background-color: transparent;">24</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6385.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">193.5</td> <td align="right" style="border: 0px black; background-color: transparent;">24</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6454.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">195.18</td> <td align="right" style="border: 0px black; background-color: transparent;">24</td> <td align="right" style="border: 0px black; background-color: transparent;">17.3</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6520.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">196.61</td> <td align="right" style="border: 0px black; background-color: transparent;">25</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6551.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">198.07</td> <td align="right" style="border: 0px black; background-color: transparent;">25</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6596.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">199.57</td> <td align="right" style="border: 0px black; background-color: transparent;">26</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6673.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">200.79</td> <td align="right" style="border: 0px black; background-color: transparent;">26</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6698.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">202.46</td> <td align="right" style="border: 0px black; background-color: transparent;">26</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6749.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">203.56</td> <td align="right" style="border: 0px black; background-color: transparent;">26</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">7020.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">205.04</td> <td align="right" style="border: 0px black; background-color: transparent;">27</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6124.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">204.24</td> <td align="right" style="border: 0px black; background-color: transparent;">27</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5307.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">203.84</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5427.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">203.12</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5393.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">202.65</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5391.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">202.24</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5441.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">201.19</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5428.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">201.17</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5444.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">201.3</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5505.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">201.34</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5537</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">202.42</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5586.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">203.68</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5634.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">205.35</td> <td align="right" style="border: 0px black; background-color: transparent;">28</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5665</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">206.81</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5675.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">208.41</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5712.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">209.64</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5775</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">210.78</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5772.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">212.14</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5834.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">213.39</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5842.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">214.75</td> <td align="right" style="border: 0px black; background-color: transparent;">29</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5900.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">215.91</td> <td align="right" style="border: 0px black; background-color: transparent;">30</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5934</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">217.36</td> <td align="right" style="border: 0px black; background-color: transparent;">30</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5986.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">218.46</td> <td align="right" style="border: 0px black; background-color: transparent;">30</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6029.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">219.53</td> <td align="right" style="border: 0px black; background-color: transparent;">31</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6013.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">221.12</td> <td align="right" style="border: 0px black; background-color: transparent;">31</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6060.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">222.2</td> <td align="right" style="border: 0px black; background-color: transparent;">31</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6100.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">223.16</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6119.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">224.45</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6156</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">225.47</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6203.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">226.84</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6191</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">227.84</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6259.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">228.93</td> <td align="right" style="border: 0px black; background-color: transparent;">32</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6270.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">229.73</td> <td align="right" style="border: 0px black; background-color: transparent;">33</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6303.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">231.09</td> <td align="right" style="border: 0px black; background-color: transparent;">33</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6306.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">232.22</td> <td align="right" style="border: 0px black; background-color: transparent;">33</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6341.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">233.13</td> <td align="right" style="border: 0px black; background-color: transparent;">34</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6881.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">233.68</td> <td align="right" style="border: 0px black; background-color: transparent;">34</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">6243.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">233.21</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">4994</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">232.74</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5134.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">231.98</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5140.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">233.26</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5193</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">234.04</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5185.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">235.04</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5221.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">235.61</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5234.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">236.67</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5265.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">237.54</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5256.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">238.63</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5278.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">239.24</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5329.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">240.04</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5329.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">241.05</td> <td align="right" style="border: 0px black; background-color: transparent;">35</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5368.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">242.11</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5386.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">242.91</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5406.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">244.01</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5408.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">244.8</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5437</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">245.51</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5452.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">246.7</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5469.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">247.61</td> <td align="right" style="border: 0px black; background-color: transparent;">36</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5495.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">248.48</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5544.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">248.75</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5496.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">250.34</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5551.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">250.56</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5550.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">251.51</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5570.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">252.54</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5602.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">252.9</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5615.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">253.88</td> <td align="right" style="border: 0px black; background-color: transparent;">37</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5656</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">254.34</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5645.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">255.52</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5656</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">255.84</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5701.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">256.91</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5681.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">257.5</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5711.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">258.35</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5748.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">258.72</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5736.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">259.69</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5736.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">260.41</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5772.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">261.13</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5822</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">261.55</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5834.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">262.39</td> <td align="right" style="border: 0px black; background-color: transparent;">38</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5803</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">263.3</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5841</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">263.57</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5849.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">264.45</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5865.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">264.9</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5849.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">265.71</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5889.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">266.5</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5897.5</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">267.05</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5908.75</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">267.63</td> <td align="right" style="border: 0px black; background-color: transparent;">39</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr> <tr height="20" style="height: 15pt; mso-height-source: userset;"> <td height="20" align="right" style="border: 0px black; height: 15pt; background-color: transparent;">5768.25</td> <td style="border: 0px black; background-color: transparent;"></td> <td align="right" style="border: 0px black; background-color: transparent;">268.46</td> <td align="right" style="border: 0px black; background-color: transparent;">40</td> <td align="right" style="border: 0px black; background-color: transparent;">16.5</td> </tr></tbody></table>
Old Nov 2, 2013 | 02:47 PM
  #119
93ls1rx7's Avatar
93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !93ls1rx7 Is a GOD !
So this is what it looks like to me in a VERY simplified snapshot:
@100kmh: all 3 have about a 4 degree delta (Aero was actually a degree higher at this point but close enough)
@200kmh: .1 is 32, .2 is 17 and Aero is 10-12 delta
@230kmh: .1 is 43, .2 is 26 and Aero is 17-19 delta
One thing I have a question about is where are the RPMs coming from? I thought this test was being done outside of your car.
Also are you going to post the FVD results or no because they did the test and you will let them report?
Old Nov 2, 2013 | 02:53 PM
  #120
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
Dude i don't think you understood what I posted maybe you should re-read what I said.
Which was the test results shall be posted next week.
For the time being I posted results from durametrics to show some real world comparisons against my cores vs gt2 rs and gen 1 cores.
So thats where the revs are coming from.
I shall post all results but you might not be able to view them as they will be a PDF since your computer thinks its a virus.
