The Ultimate GIAC/Champion Motorsport 68mm VTG Upgrade Thread!
Old Oct 10, 2013 | 01:01 PM
  #46
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
Originally Posted by Thomas@GIAC
This was on the race file for 100 octane.
Using pump + meth injection?
Old Oct 10, 2013 | 01:08 PM
  #47
Andrew@GIAC's Avatar
Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !Andrew@GIAC Is a GOD !
Pump/race mix with water-methanol injection.
Old Oct 10, 2013 | 03:12 PM
  #48
I was able to pull this run from the setup noted on the original post. This car has:
Champion 68mm Turbos
GIAC ECU Software
GIAC TCU Software
Stock Turbo Inlets
2.5" Exhaust
Stock Injectors
100 octane fuel
This run was taken from No Fly Zone Airstrip event in Bakersfield, 03/02/2013. Temperature at this event was 82 degrees, at an elevation of 424 feet. This gives us a density altitude of around +2100 feet. You can see that even in a higher density altitude, the car shaved off over a second in the 60-130 by adding the air and fueling supporting modifications.
Champion 68's, stock fueling, stock inlets: 7.99 60-130 (+2100 DA)
Champion 68's, upgraded fueling and inlets: 6.76 60-130 (+2800 DA)
Old Oct 10, 2013 | 05:08 PM
  #49
rix's Avatar
rix
rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !rix Is a GOD !
Do the Champion 68mm turbos have extrude honed turbine housings?
Old Oct 11, 2013 | 10:18 AM
  #50
Not to my knowledge, but if this is something you want I imagine that it could be arranged. The turbine housings are modified though:
https://www.6speedonline.com/forums/...explained.html
Old Oct 11, 2013 | 10:30 AM
  #51
DNugget991GT3's Avatar
are 997tt turbos the same size as gt2/gt2 rs turbos ?
is one better off "hybriding" the factory turbos, or getting gt2 turbos and hybriding those?
Old Oct 11, 2013 | 10:38 AM
  #52
Here is Champion's explanation of the differences:
Old Oct 11, 2013 | 10:40 AM
  #53
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
997TT and GT2 turbos are slightly different, mostly on the turbine side. GT2RS turbos are totally different. They're almost like a hybrid between .1 and .2 turbos.
Old Oct 11, 2013 | 02:24 PM
  #54
Updated first page with some more racing footage.
Old Oct 11, 2013 | 11:05 PM
  #55
blindfold's Avatar
blindfold is a glorious beacon of lightblindfold is a glorious beacon of lightblindfold is a glorious beacon of lightblindfold is a glorious beacon of lightblindfold is a glorious beacon of lightblindfold is a glorious beacon of light
how would these turbos translate into power output for PDK 997.2 tts on 91 Cali gas? Or is it something not advisable on on PDK and newer engine?
Old Oct 14, 2013 | 07:29 AM
  #56
Your answer is here:
https://www.6speedonline.com/forums/...ck-turbos.html
Old Oct 14, 2013 | 09:20 AM
  #57
alexo's Avatar
alexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the roughalexo is a jewel in the rough
how far is giac/champion from 1000+hp on the new 3.8 dfi's
and will it ever be possible in your opinion after experimenting for a couple years now on the 997.2 and soon the 991
Old Oct 14, 2013 | 09:29 AM
  #58
Yes, it's definitely possible on the 997.2 cars. The only problem is that it's EXPENSIVE! To get there, you need a built engine, modified and reinforced PDK, and fuel system. Altogether, the cost of doing all three has really prohibited anybody from taking the leap and doing it. I've got a few customers who might be interested, but none have taken the leap yet.
Old Oct 14, 2013 | 10:13 AM
  #59
alexo's Avatar
approximately how much are we talking about? and hopefully with time... the production costs and r&d will be reduced... we need some pioneers with some deep pockets uh
Old Oct 14, 2013 | 12:48 PM
  #60
rix's Avatar
rix
If you look at GTR pricing it would probably be well over $100k to do it right. A full tilt GTR trans is over $40k on its own.
