ipad mini professional installations
If the Lake Forest area is not too far for you, email me....I may have someone for you.
eric@bumperplugs.com
If the Lake Forest area is not too far for you, email me....I may have someone for you. eric@bumperplugs.com
Thanks you for your response, I am in Hemet CA it is about an hour and 20 minutes to get to lake forrest so is not that far, how much you think it'll cost to do the installation?
Thank you!
I've hear a lot of good things about it the only problem I see is the rear view camera?
I have to install somewhere an ipad mini too as i run syvecs and i want to monitor everything.. Pcm is not an option though as i retrofitted pcm3 which i like so much... I am thinking to find a clever base or sth with magnets.. (To hold the mini ipad) like the original screen protector...) any ideas?
Check out proclip. Here is a link to the mounting options. You would also pick the type of cradle that holds the device to this (powered or non powered).
I have the phone holder for my Galaxy S3 in both my 997 turbo and my turbo cayene. Works great.
http://www.proclipusa.com/dashboard-...-997/2008.cmsv
https://www.6speedonline.com/forums/...ini-997-a.html
He was very detailed in the install and follow up.
That would be the cleanest installation for you.
